Back of Driver Instrument Cluster
Old Feb 11, 2021 | 03:17 PM
jpatrick62's Avatar
jpatrick62
Default Back of Driver Instrument Cluster
Well it started with replacing the weatherstripping trim on my 69 convert, and it has grown to:
1. Removing and refurbishing the wiper linkage and door tray.
2. Removing the windshield after some rust was spotted in Windshield frame.
3. Removing the driver and center gauge clusters to better spot more intrusive rust (thankfully not - limited to one spot on the windshield frame).
4. Will probably replace dash harness while I'm here.
Anyway, When I removed the driver side gauge cluster I noticed some surface rust on the backs of the cluster and would like to fix this. Once I remove the rust, should I spray a clear coating to sop any new formation? How can I keep the rust
off this cluster in the future?
I'd like to remove this rust and keep it off!
Old Feb 11, 2021 | 04:58 PM
aquaroscoe's Avatar
aquaroscoe
The lights get grounded to this housing. I suspect any clear coat will make this a problem
Old Feb 11, 2021 | 05:38 PM
Mooser's Avatar
Mooser
You can clean them, clear coat, paint, whatever but make sure the areas where the lights plug in are bare for grounding those circuits
Also where the actual ground wire connects over to the headlight switch, etc
M
Old Feb 11, 2021 | 07:00 PM
jpatrick62's Avatar
jpatrick62
Thanks guys - yeah I would make allowance for the grounding of the unit - I just didn't know what others have done to clean this up. Mooser, that is a really clean looking cluster housing!
Old Feb 12, 2021 | 12:06 PM
Sayfoo's Avatar
Sayfoo
SOME rust removing products leave a phosphate finish/coating that is rust resistant.
The one I used years ago left the metal a light gray color.
I don THINK this would be anti conductive, but it would be easy to check with a vom or a test light.
FYI R&R'ing the dash was the worst job I've done on my '69.
It comes out easily, but was hard to get back in. The huge bundle of wires has to be in exactly the right place for the assembly to fit back in.
**the thin fiberglass housing will crack easily when you are trying to install it. DO NOT FORCE IT**
Adding to the drama, there is a difference between the early and late '69 routing of the big wire bundle.
Also, it might be easier to reinstall if you remove the extra braces used on convertibles and install them afterwards.
Good luck.
Old Feb 12, 2021 | 08:12 PM
jpatrick62's Avatar
jpatrick62
Thanks for the advice - I'll be careful when the time comes. And FWIW, getting the dash cluster out was no walk in the park either - it was difficult to get my fat hands behind the cluster to spring the speedo andtach cables...
To Back of Driver Instrument Cluster
