79 wiper problem
Old Feb 21, 2021 | 04:25 PM
Drwcifer's Avatar
Drwcifer
Default 79 wiper problem
Hey guys. The wipers quit working on my 79 c3. There is a clicking sound inside the dash somewhere behind radio cluster. Is there a relay back there?
Old Feb 21, 2021 | 05:10 PM
theandies's Avatar
theandies
If it's in the same place as my "71 the wiper relay should be slightly in front of the ashtray under the center console. If you hear a clicking noise then the relay is at least working to some degree although the power side contacts may be corroded or carboned over causing no current flow.
Again Willcox to the rescue, What a valuable resource.
Old Feb 21, 2021 | 09:40 PM
interpon's Avatar
interpon
Sounds stupid ..but try running them with hood up..
i thought mine broke and realized it was hitting hood and stuck..need low profile wipers..
also discovered i had intermittent wipers ..
https://www.corvetteforum.com/forums...ting-hood.html
To 79 wiper problem
