Power window motors
Old Feb 27, 2021 | 07:04 PM
xpoc454's Avatar
xpoc454
Default Power window motors
I've got a set of rusty power window setups. Im trying to save the motors by seperating them from the arms.
easy enough but is there a way the gear attached to arms can be removed and added back to the motor,
Also to test if these are functional, do I just connect a battery positive and negative to the 2 connections on the motor,?
thanks
Old Feb 27, 2021 | 07:08 PM
xpoc454's Avatar
xpoc454
The part numbers are 1697346 7 1-76
and 1697345 2 22-76
Old Feb 27, 2021 | 07:56 PM
drwet's Avatar
drwet
Connect the negative terminal to the body of the motor. Connect positive to one of the terminals. One is up and the other is down.
To Power window motors
