69 427 alternator bracket questions
Old Mar 8, 2021 | 03:50 PM
Hdmike444's Avatar
Hdmike444
Default 69 427 alternator bracket questions
Hi all
my car came to me with a horrible belt squeal. The power steering pump and alternator were off kilter from the other pulleys, I seemed to have straightened out the PS but the alternator is still off, it seems like it needs to roll up and towards the rear of the car. The one issue I have is the alternator is a 1/16” away from the valve cover, I’m also not sure the belt is correct, it seems like it needs to be longer. I am still trying to figure this out. The brackets I believe are aftermarket and could be the problem but not sure, does anyone have pics of the full assembly and or real bracket pics to compare to. Or possibly good factory brackets to sell if that is my issue.
I appreciate any help
Old Mar 8, 2021 | 04:02 PM
NMT1957's Avatar
NMT1957
Mine is close to the alternator and I do have the correct brackets and belt. 427-400
Old Mar 8, 2021 | 04:03 PM
NMT1957's Avatar
NMT1957
I do remembering having to tweek one of the brackets a little to get it to line up.
Old Mar 8, 2021 | 04:42 PM
Hdmike444's Avatar
Hdmike444
What belt are you running?
Old Mar 8, 2021 | 04:54 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
that lower Alt bracket is prone to cracking at the adjustment point. I would look over them for stress cracks
Old Mar 8, 2021 | 07:07 PM
Hdmike444's Avatar
Hdmike444
No cracks that I can see
Old Mar 8, 2021 | 07:30 PM
Sayfoo's Avatar
Sayfoo
I see 2 things.
1 NMT1957 The bracket that runs over the top of the PS cap can be rotated end over end to give more clearance to check the fluid.
2 OP your belt sits pretty low in the pulley groove. IF, it is riding on the bottom of the pulley, a wider belt will give it more traction as it is off the bottom and you get more side friction. But, I do also remember reading that Chevy was concerned about throwing belts, and did spec deep pulleys for some 390 and 400 hp engines. A wider belt will not be the same length as the narrower one, and may take a bit of trial and error to fit correctly.
A glazed belt can sometimes be fixed by wiping it down with acetone. Do not use any of the belt dressing goop available.
I did use a few washers to get my bracket/pulleys to line up better.
Old Mar 8, 2021 | 07:42 PM
NMT1957's Avatar
NMT1957
Sayfoo,
Thanks for that. I will be turning mine end for end and try that.
Old Mar 8, 2021 | 10:39 PM
ed427vette's Avatar
ed427vette
I believe the water pump pulley on all 69 427’s should have 3 grooves. You pulley has two grooves. That in itself may be causing you a problem.
Old Mar 9, 2021 | 07:50 AM
Hdmike444's Avatar
Hdmike444
In looking around it should be a 3 groove, now to find one. In a perfect world I’d like an original, is that going to be impossible? If so who should I buy an aftermarket one from?
im still not sure this will help the alternator being out of whack. I will try a wider belt as well.
Old Mar 9, 2021 | 08:11 AM
kossuth's Avatar
kossuth
While I’m not sure of this either I know on the 68s it’s a 3 groove deal, I assume it should be the same on a 69. Not saying this is the issue but I’d look into it.
Old Mar 9, 2021 | 08:18 AM
kossuth's Avatar
kossuth
Not sure who the best source would be. Not a bash to any vendor but generally speaking anything from Paragon or Corvette Central you shouldn’t have any issues with.
Also, check your crank pulley. Make sure that isn’t the source of your weirdness. Given things have been changed around over the past 50 years by various bubbas (yes I’m a bubba too) anything is suspect TBH. Keep in mind that the OE water pump for the corvette was a short unit which was unique to the corvettes. You might find that you have a couple of things wrong.
Old Mar 9, 2021 | 08:33 AM
John 65's Avatar
John 65
Check this thread out for your pulley. Part # 90840 was from a Mercruiser boat engine.
https://www.corvetteforum.com/forums...for-cheap.html
I used one on my 68 years ago and it worked fine. In fact I just got another last week from ebay for a fraction of a correct one for a future BB project.
Hats off to 540vette on this one.
Old Mar 9, 2021 | 09:27 AM
Hdmike444's Avatar
Hdmike444
what belt are you running on the alternator
Old Mar 9, 2021 | 09:28 AM
Hdmike444's Avatar
Hdmike444
how do I confirm my waterpump is correct
Old Mar 9, 2021 | 09:51 AM
ed427vette's Avatar
ed427vette
The original cast number was 3856284 which you would see cast on the pump. Chances are it’s a replacement you have. I do not believe this was unique to the corvette big block. This pump was used on many Chevrolet big blocks from 1965 thru 1969. Check to see what number is on your pump and look it up to see if it’s a correct replacement for a “284”.
To 69 427 alternator bracket questions
