Here we go again
Old Mar 14, 2021 | 03:46 PM
VinniePG's Avatar
VinniePG
Default Here we go again
Another electrical question. 1975 coupe. This is attached to the drivers side panel , just a little in front of kick plate. Any iideas on what it is?
Old Mar 14, 2021 | 04:06 PM
domenic tallarita's Avatar
domenic tallarita
looking at the wire connectors, I would say it
s not stock. Looks like a relay.
Dom
Old Mar 14, 2021 | 04:21 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Dom
Could it be that the OEM connector melted because of a short and the P.O. replaced the relay and connector with aftermarket parts (I'm making a guess without a good wiring diagram)?
Old Mar 14, 2021 | 05:55 PM
Factoid's Avatar
Factoid
That is an aftermarket relay that looks to be part of an anti-theft system.
Old Mar 15, 2021 | 08:12 AM
Bikespace's Avatar
Bikespace
4 crimp connectors, but I only see 3 wires. If it is a relay, it isn't doing much.
See if you can trace where the wires go. It may well be a standard automotive relay, like the diagram below (If it only has 4 spades, terminal 87a, normally closed, has been omitted).
Old Mar 15, 2021 | 11:11 AM
Factoid's Avatar
Factoid
Thats why I think is was originally an anti theft relay. The purple wire is probably to the starter. You can see an open connector. My theory is one of the purple wires used to go to the open connector, but some PO cut it and crimped to the other purple wire so the car would start. Who ever that PO was did some Bubba work.
Old Mar 15, 2021 | 06:35 PM
Bikespace's Avatar
Bikespace
Sounds plausible. It was bypassed just like so many clutch safety switches. Perhaps Bubba thought he was going to get around to fixing it one day.
Old Mar 15, 2021 | 07:01 PM
Richard454's Avatar
Richard454
Well the official name- "Stater Interrupt Module"-
That's why they sold for a lot more than a "Bosch style relay!!!"
It look like is has been jumped- but not really well.
I'd disconnect the battery- peel back the tape-then trace the wires-
Might find a momentary switch-and probably a wire tapped off the ignition.
And you'll want to make a more permanent connection of the two purple wires- as that could lead to a no start situation.
Let us know!!!
Momentary switch- usually something similar to this
To Here we go again
