1/8" Hard line Sources?
Old Mar 18, 2021 | 06:23 PM
Mike H.'s Avatar
Mike H.
Default 1/8" Hard line Sources?
Hi,
I have a '70 with rusty/ broken 1/8" hard lines that go to the the rear venting system. Does anyone have a source to replace these lines?
Thanks, Mike
Old Mar 18, 2021 | 07:39 PM
PJO's Avatar
PJO
Veteran: Marine Corps
Could only find stainless steel
Grainger
https://www.grainger.com/category/pl...&filters=attrs
McMaster-Carr
https://www.mcmaster.com/tubing/meta...r-flow/od~1-8/
Old Mar 18, 2021 | 07:40 PM
Jeffs82c3's Avatar
Jeffs82c3
I think inline tubing sells them
Old Mar 18, 2021 | 07:53 PM
Richard454's Avatar
Richard454
Here's 1/8" in easy to bend aluminum-
https://www.mcmaster.com/tubing%2Fme...uminum-tubing/
Old Mar 18, 2021 | 07:58 PM
Norm07's Avatar
Norm07
I used 1/8” copper from a local hydraulic supply store. Easy to bend, worked great, not a lot of money.
Old Mar 18, 2021 | 08:03 PM
Mooser's Avatar
Mooser
Stainless off amazon
M
Old Mar 18, 2021 | 10:43 PM
7T1vette's Avatar
7T1vette
I would recommend using NiCu (nickel-copper) brake/fuel line for that task. It comes in 1/8" size; it is easy to bend and form flare fittings (or compression fittings if required); and is impervious to fuel, oil, brake fluid, and water. Get it at most auto parts stores.
Mike H.'s Avatar
Mike H.
Thanks for all the replies. I'll check them out.
Thanks, Mike
To 1/8" Hard line Sources?
