4 speed transmission
Old Mar 24, 2021 | 11:58 AM
codydog69's Avatar
codydog69
1st Gear
Default 4 speed transmission
my 4 speed transmission will not go in gear when running,,but it goes into gear when not running, it doesnt get driven alot last time I drove it it was fine just been sitting for awhile.any suggestions
Old Mar 24, 2021 | 12:02 PM
Young Vette's Avatar
Young Vette
Does it happen to go into gear after sitting and waiting with the clutch pressed in for a while? My guess would be that the first gear synchro is a bit worn and is having trouble slowing down the input shaft enough to get everything meshing.
Old Mar 24, 2021 | 12:30 PM
MelWff's Avatar
MelWff
With the engine off, pressing down on the clutch pedal with your hand, do you have a liitle more than 1 inch of movement before you feel it stop?
Old Mar 24, 2021 | 05:29 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
If it has been sitting a long time maybe the clutch disc is stuck to the flywheel
Old Mar 24, 2021 | 07:01 PM
L-46man's Avatar
L-46man
Your clutch plate is stuck to the fly wheel. Rust.
Old Mar 24, 2021 | 09:32 PM
Bluesting70's Avatar
Bluesting70
2024 Corvette of the Year Winner - Modified
2023 C3 of the Year Winner - Modified
I have a BW 4 speed I just took out for a 5 speed if you are interested.
Old Mar 24, 2021 | 09:41 PM
SHARKBIT77's Avatar
SHARKBIT77
Put it in first and turn the key. Car will jump forward and may pop the disk lose. Use caution. It may take a couple try's.
Old Mar 25, 2021 | 11:20 PM
firstgenaddict's Avatar
firstgenaddict
With the engine off - Can you put the car in first or reverse - depress the clutch pedal - start the car?
OR does it lurch forward/backward?
if it lurches with the clutch pedal depressed the disk is stuck to the flywheel -
You should be able to fire the engine off with the pedal depressed and the trans in any gear.
To 4 speed transmission
