Bouncing Headlights
Old Apr 11, 2021 | 11:54 AM
Roy W.'s Avatar
Roy W.
Disabled by request 8 JUN 2025
Default Bouncing Headlights
When driving at night in my '81, I see my headlight beams vibrating slightly. Is this common or is something out of adjustment.
Old Apr 11, 2021 | 12:44 PM
Mooser's Avatar
Mooser
If they aren't all the way up against the stops then they will flutter, if the stop is there and the spring(s) are broken that hold it to the stop then they will also flutter
M
Old Apr 11, 2021 | 04:46 PM
Roy W.'s Avatar
Roy W.
Thank you.....I will check for stops. I only know they go "clunk" when they come up.
Old Apr 11, 2021 | 04:50 PM
Mooser's Avatar
Mooser
The clunk could just be the rest of the mechanism, there's a lot of stuff moving
M
The earlier ones had a stop bolt at the bottom, yours should have slots at the top/side to adjust but anyway, check that the bottom part if firmly touching the frame when it is up. I don't know if yours would have a cushion where it hits or not
Old Apr 18, 2021 | 11:00 PM
ledger35's Avatar
ledger35
I see absolutely nothing wrong with bouncing headlights. Bouncing Betty’s
Old Apr 18, 2021 | 11:52 PM
theandies's Avatar
theandies
Also make sure the headlight rings that hold them into the cup hold them tight.
To Bouncing Headlights
