Tank Sticker
Old Apr 12, 2021 | 10:45 PM
1972corvette454's Avatar
1972corvette454
Default Tank Sticker
I own a 72 Corvette 454 / four speed
Besides the Tank sticker were there any other areas of the Corvette where the documentation was placed?
(Behind the dash?)
Vic
Old Apr 13, 2021 | 12:27 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Yes, behind the dash is one spot you may find it. I've also heard of them stuffed under a seat. I found mine behind the driver side dash.
Old Apr 13, 2021 | 04:47 PM
1972corvette454
Thanks this is what I have only.
72 / 454 tank sticker
Old Apr 13, 2021 | 09:18 PM
PJO's Avatar
PJO
Veteran: Marine Corps
Sometimes the delivery truck driver placed a sheet in the passengers side map pocket. Plus your 72 has 2 pages that means lots of options.
Old Apr 13, 2021 | 10:35 PM
KingRat's Avatar
KingRat
(Behind the dash?)
Vic
Found my '72 LT-1 Build sheet over the right rear body mount when I removed the carpet.
I know of a '69 L-88 where they rinsed the inside of the frame before restoration and a second build sheet washed to one of the openings in the frame.
Old Apr 14, 2021 | 08:48 AM
pltmgr's Avatar
pltmgr
If you can't find a second build sheet take a closeup photo and try manipulating the photos - darker, lighter etc..My tank sticker was very hard to read/ torn but doing this and comparing it to a legible build sheet from that year I was able to decipher all the lines
Old Apr 14, 2021 | 06:41 PM
LeeS's Avatar
LeeS
Great advice above, other documented possibilities are behind the kick panels, (you can check the body mounts as well). And behind the carpet in the kick up panel behind the seats.
To Tank Sticker
