When I bought this car, it had a Summit circle track cam in it. It is extremely lopey and sounds great, but it does not like to idle, has no low end power, and has so much overlap at idle you might as well put your face in a bucket of gasoline.
I'm in the process of pulling the engine now for a yet determined problem, but while it's out, I'm going to swap it for something a little less aggressive.
Any recommendations? Looking for something hydraulic that still sounds fancier than stock but it more street-able.
That 106 LSA is what is killing it, plus that is just a big cam.
I would go with some in the 112 to 114 range with a mid 220 intake and mid 230 exhaust. Will run good have good power everywhere and sound like it has a cam
What trans, gearing do you have? Hard to give an answer really.
stock compression and heads?
Dave at Crower Cams and Ron at Isky can get you the right one the first time.
Its impossible for anyone here to pick the perfect cam for your app w/o any data on your engine.
It requires about 20 questions to verify exactly what you have and what your intentions with the vehicle will be.
Please, call a pro at any of the cam manufacturers and have them set you up. Its what they are paid to do.
That was a nice cam in my L-82 but I had about 1 more point of compression over stock with Kieth Black domed pistons and 4.030" bore, stock 2.02" heads. Ran really well.
Stock heads besides just rockers, original L48 block bored out with original T10 transmission
Its impossible for anyone here to pick the perfect cam for w/o any data on your engine.
Not really asking for anyone to pick the perfect cam for my car, just asking for what types people are running and happy with.
I'm guessing I have about 11:1 with flat top pistons and 4.030" bore
The cam you choose depends very much on your compression ratio. Do some research on 'dynamic compression ratio' and select a cam that will give you about 8.5:1 with aluminum heads or about 8:1 with cast iron. Personally I like about 224 degrees of intake duration (@ .050") and a 110 deg. LSA. You might want to use a dual pattern cam with a little more exhaust duration depending on your heads. To me these numbers represent a nice compromise between performance and driveability, but if you put one in an engine with too much compression you will have a detonation problem. If you put it in an engine with too little compression it will be a dog.
I agree your engine has way too much cam. Sounds cool but it must be a bear to live with.
If those heads are 76cc your compression is somewhat low
64cc without the block or heads decked youd be lucky to see 10:1
Pistons can be .025 to .045 in the hole
If you pop a valve cover there will be a part number cast in (they are raised). What are the last 3 digits?
Id be temped to say an Iaky 270 mega cam without knowing more.
Sounds good makes more torque than the 350hp cam. Fun to drive, will work power brakes
Can be used with a stock converter but works real good with a 2600
Dual patterns with tight lsa blow all your torque right out the tailpipe unless you got lots of rpm
Opinions may vary...man would an upgraded set of heads wiht that cam be fun...nice 180cc piece.
Agree with the above. Talk to a pro at the cam mfgrs. Or 2 or 3.
Stay under 230 degrees or less for a great street cam. 230 and above you very quickly sacrifice idle quality/vacuum/low rpm TQ
In your case it is not the 230 degrees that is killing it, it is the extremely tight race only 106 lobe center. That needs to go!
110 to 112 is probably a minimum.
The rest of the details will depend on you compression, gearing and intended use. Have all that available before you call or they can not really help you.
BTW my 230/240 duration roller on my 454 generates 15 " of vacuum at idle due to it's 110LC. Sounds great and has peak TQ at a low 3300 rpm with a 2200-6300 powerband.
