turn signal flasher
Old May 1, 2021 | 04:26 PM
mkcorvette's Avatar
mkcorvette
Cruising
Default turn signal flasher
Does anyone know where to buy a turn signal flasher (1975 corvette)? This is the thinner flasher under the passenger dash. I can only find the thinker hazard flasher that goes with all the fuses.
Old May 1, 2021 | 06:11 PM
Mooser's Avatar
Mooser
Any NAPA or whatever you've got locally should have them. Nothing special, pretty much the same on every chev built in the 60-70-80+ used the same ones
Tridon EL12, Standard EFL552, etc all should work
M
Old May 1, 2021 | 06:46 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
They should be the same. you should be able to switch them back and forth to test/ check them.
To turn signal flasher
