C3 Windshield Frame
Old May 4, 2021 | 03:41 AM
Dhoward's Avatar
Dhoward
1st Gear
Default C3 Windshield Frame
I bought a 72 convertible and discovered that the upper windshield frame (sides and top) are completely rusted out. I understand that this is somewhat typical but a bummer.
Can anyone tell me what years have the exact same frame that could be used to replace my rusted one? I found one for sale in my area that is listed as matching for a 78-82, and it looks like it might be the same, but I am not sure.
Looking for help to determine what years would work as an exact replacement.
Thanks Everyone!
Old May 4, 2021 | 07:25 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Thanks Everyone!
If it is rusted on top and sides then be sure to check down the birdcage behind the kick panels to make sure you are not looking at that lower portion replacement as well. Rot usually continues down the birdcage, ask me how I know.
There were no convertibles in 78-82; last ones were built in 1975; so that window frame will be for a coupe which is not the same.
Best bet would be a donor from a 69-75 convertible.
Good luck with your search.
David Howard
AllVettes4Me
Old May 4, 2021 | 07:40 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Thinking if the windshield frame is that bad. I too would be overly concerned about the rest of the birdcage.
Old May 4, 2021 | 08:28 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
heres one for sale on our parts page, its for T tops ..... but the pics will give you and idea of how the water could travel down to the body mounts and what you will need to replace...
https://www.corvetteforum.com/forums...e-section.html
Old May 4, 2021 | 06:01 PM
derekderek's Avatar
derekderek
you can use a r top frame in a convert. gotta remove the center piece, but by that time you will be well versed at drilling and separating spot welds...
Old May 4, 2021 | 06:34 PM
caskiguy's Avatar
caskiguy
Willcox write up on repair: http://repairs.willcoxcorvette.com/w...stallation.pdf
To C3 Windshield Frame
