Trying to decipher this engine!
Old May 9, 2021 | 12:51 PM
bowtie0069's Avatar
bowtie0069
Cruising
Default Trying to decipher this engine!
I just acquired an engine that has me somewhat baffled. The block suffix is HP, and the casting date is G 10 8 on the 3914678 casting, so I'm assuming it's a 69 350/300 for A, B, F and X bodies with a manual trans (I can see wear on the bushing, so it obviously was a manual trans). But, the intake manifold (dated F 20 8) has the oil filler tube that should have discontinued in 1968, although I've heard some very early 69's may have still had the filler tube. It has 186 heads dated H 2 8 and H 3 8. But, it also has the brackets for the ignition shielding like on a Corvette. The distributor is missing, so I don't have info on it. It also has what may have been a block heater on the drivers side rear freeze plug. Anybody ever see an animal like this? What else could tell me if it actually came in a Corvette?
Old May 9, 2021 | 01:04 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...the BlackBook shows 3914678 as a 327, HP as 350hp, mt, ac & ps. G 10 8 would be July 10, 1968. The oil fill tube would be correct for a '68 engine.
Old May 9, 2021 | 01:39 PM
derekderek's Avatar
derekderek
no one list the HT suffix code as any 68 engine. but i have heard it is a 68 327 same as the 65-67 variants. it also shows as a non-corvette 350. i think this is the first 350 block so a bit more interesting than an 010. the vin deritive may be helpful in deciphering what it is-was... date codes imply it is an unmolested late 327 or early 350. you are new here. welcome. what is it going in? we are not the purists who scream "No Novas, Camaros or Chevelles!"
Old May 9, 2021 | 01:49 PM
bowtie0069's Avatar
bowtie0069
Cruising
Thanks, I just ran across that info while searching under Corvette applications.
Old May 9, 2021 | 01:58 PM
bowtie0069's Avatar
bowtie0069
Cruising
Derek, I have no plans for it at the moment, was just trying to determine if it was basic 350 or...?? As Paul above mentioned the HP suffix does show up as an L79 327 WITH A/C in a 68 Corvette. The manifold is what threw me because at first I saw 69 only, but it shouldn't have the fill tube, then I saw where the same casting number was used on at least 3 different manifolds. It is starting to appear it's a 327. Guess I'll just add it to my stash of multiple 327s, 350s, 305s and the lone 400 that's in my Nova.
Old May 9, 2021 | 06:15 PM
kodpkd's Avatar
kodpkd
I have a V0618HT L79. The HT is for 327 350HP High performance engine. Non ac, no power brakes or steering.
Old May 9, 2021 | 09:55 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
As others mentioned, this is an L79, 327-350 HP with AC. Is there a VIN on the pad? That would clear any doubt.
Old May 10, 2021 | 06:31 PM
bowtie0069's Avatar
bowtie0069
Cruising
18S428340 is the VIN on the pad. It also has 3883235 DS and 3876846 DJ water pump pulleys, and 3911013 BW crank pulley that is part of the A/C-P/S combo. The Q-Jet looks to be for a 300 h.p. engine (7028207 DA), but I'm sure it could have come on there due to a screwup. The 30570 A water pump is cracked and I'm not sure it is correct anyway.
It doesn't rotate easily, so I'll tear it all the way down and see what surprises await me!
Old May 14, 2021 | 07:55 PM
bowtie0069's Avatar
bowtie0069
Cruising
Today I pulled the heads and discovered it is still a standard bore, but 2 holes have had water in them. Looks like it will clean up with a hone. It has the domed pistons ,so I assume it's a real L79.
The heads still have me puzzled--they are 3927186 castings, but I can't seem to verify their use on a 68 L79. And, they look like 2.02/1.60 valves in there, yet my research says the big valve heads all had screw in studs and guide plates, which these do not.
It does have the longer sump oil pan.
Old May 14, 2021 | 08:22 PM
79SLWL82's Avatar
79SLWL82
I believe that 186 heads had press in studs until 70, then they went to the screw in studs.
I've seen several 186 heads with press in studs.
Old May 14, 2021 | 09:41 PM
bowtie0069's Avatar
bowtie0069
Cruising
In my searching, it seems only the 2.02 valved 186s on higher HP cars(like Z28s) had screw-in studs. Not so with the 1.94/1.50 versions like a 327/300.
Old May 15, 2021 | 07:29 PM
bowtie0069's Avatar
bowtie0069
Cruising
Took the engine apart today--it has the large journal forged 327 crankshaft that some say doesn't exist, f
orged pistons, 151 cam, Standard bore, original, standard size bearings dated May 1968, 186 heads with 2.02 valves...I'm about 99.99999% sure it's a real 327/350 1968 4 speed Corvette L79 engine that has never been apart.
I have a friend going to try a VIN search to see where the car may be. Maybe wrecked? Looking at the outside of the engine, I was thinking it had a million miles of neglect, but inside it's in pretty nice condition. .006" crank end play, .011" between the rod journals--I can't see why it was removed. Timing chain has gobs of slop, but...?
Old May 15, 2021 | 07:45 PM
derekderek's Avatar
derekderek
good chit mon!
Old May 16, 2021 | 10:26 AM
bigredbrad's Avatar
bigredbrad
From: Lincoln NE Riding and Driving Corvettes since 1967.
Why not just post a pic of the pad so we can help identify what you have?
To Trying to decipher this engine!
