Unknown ticking noise
Old May 18, 2021 | 10:10 PM
Joshua Ruiz's Avatar
Joshua Ruiz
Default Unknown ticking noise
Hello I’m having a problem with my 76 corvette. When I’m driving I noticed a ticking noise coming from the front it it’s only really noticeable when under acceleration. I put it in park and tried to see if I could hear it at idle and I tried giving it a bit of gas. but I didn’t hear it then. I’m thinking it could be a exhaust leak but I’m not smelling anything and it doesn’t go away after the car is warmed up. Does anyone have any suggestions on what I can do to find the noise or any idea on what it could be? Thanks in advanced.
Old May 20, 2021 | 03:39 PM
MelWff's Avatar
MelWff
Have you had it on a lift and checked where the front pipes connect to the exhaust manifolds?
Old May 20, 2021 | 08:24 PM
M A Fry's Avatar
M A Fry
It could be a wheel bearing.
Old May 24, 2021 | 02:28 AM
tankertoad89's Avatar
tankertoad89
Sounds like the most likely culprit is a blown exhaust manifold gasket.
Old May 28, 2021 | 01:33 AM
pikeinco@yahoo.com's Avatar
pikeinco@yahoo.com
4th Gear
I just fixed my 79 today. Was making a ticking, rattling sound underneath. Turned out to be the plate on the front of tranny had a bolt missing and another loose. Tightened it up and put in another bolt, problem solved. I thought it was an exhaust leak. Good luck!
To Unknown ticking noise
