Tools & tips needed to replace EBrake handle on 69.
Old May 20, 2021 | 02:05 PM
bosco1's Avatar
bosco1
2022 C7 of the Year Finalist - Unmodified
2015 C3 of Year Finalist
Default Tools & tips needed to replace EBrake handle on 69.
Hey guys I'm replacing my 69 EBrake handle only. What tools do I need to do this?
Old May 20, 2021 | 02:13 PM
bazza77's Avatar
bazza77
Firstly I would put some rust penetrating fluid around that big roll pin in the centre of that handle .That's the piece that you have to push out . A big pin punch to suit that as well. Maybe pliers to pull on it while you tap it out with a mallet as well.
I did mine on a bench , I was worried about distortion so I braced it closer to the pin area .
Old May 20, 2021 | 02:23 PM
bosco1's Avatar
bosco1
Ok thank you, Will I be able to reuse the pin....
Old May 20, 2021 | 02:26 PM
bazza77's Avatar
bazza77
Yeah , I reused mine . Holds nice and tight.
Old May 20, 2021 | 02:32 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Rookie question: Will the cable preload spring need to be temporarily unhooked on one end of it under the car so there will be no tension on the E-brake handle when the roll pin is removed?
Old May 20, 2021 | 02:57 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
You pretty much have to loosen the nut that adjusts the cable from the handle to the cable that connects the rear brakes.
It's one of those you have to disassemble everything just to replace the handle. Good 'ol Corvette engineering.
Old May 20, 2021 | 03:04 PM
bosco1's Avatar
bosco1
Does it matter which side you are punching out? They look very similar on both sides.
Old May 20, 2021 | 07:39 PM
doorgunner's Avatar
doorgunner
Is there a small bevel on one end of the roll pin...if so...the bevel end goes into the handle first when you reassemble it. I grind the bevel about 1/32" longer to help it drive in straighter.
Old May 20, 2021 | 10:58 PM
Eliredandblack's Avatar
Eliredandblack
You will have to get under he car and loosen the adjustment nut that will give you enough slack on the cable to get the e brake handle out of the car. Some of the vendors sell the correct size punch with the new handle, I went to Harbor Freight and bout a set with several sizes. You only need to loosen tension on the cable enough to remove the e brake handle.
Old May 21, 2021 | 07:06 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
you can use a short bolt as a punch with a C clamp and a socket on the reverse side as a receiver for the roll pin
To Tools & tips needed to replace EBrake handle on 69.
