Another Serpentine Accessory Conversion
I know this has been beat to death and there are numerous posts on a serpentine conversion for our cars. I swear I have read them all. However I have a few differences from a stock 72, and was hoping someone might have had the same set up prior to converting to a serpentine system. I have yanked several systems from wrecking yards in the past for installation in small block Jags with minuscule hood clearance like our corvettes on the cheap with great results. However my small block 72 has an upgraded (larger cs144) alternator that I would like to keep, and an upgraded modern Sanden style A/C compressor I would also like to keep. I have an electric fan so front clearance is sufficient where I wouldn’t have to try and find a reverse rotation short water pump (if there even is such an animal). Guys I know there are a large assortment of choices for a serpentine system in our cars, but I am hoping someone has installed one with the CS144 alternator and Sanden style A/C compressor.
Thanks guys. Dave
Bad news is....you may have to cut sections out of the 1-piece accessory mount.......I bolted a mount in place on the engine (drilled new mount holes to lower the entire piece first) and spent a day cutting and relocating/re-welding sections onto the mount to get the clearances I needed when the components were installed.....
You may be able to cut individual component sections off the original mount and re-drill mount holes/bolt them to the engine rather than re-designing the whole mount.
example of an original mount below.......the black spraypaint makes it difficult to see where I cut/lowered sections so the components would clear the hood/a-arms/valve covers/etc. In some places I only needed to remove pieces of the mount where the component such as the large alternator "bottomed-out" on the stamped metal....basically, I cut radius sections out whenever possible to "lower" the components.
(pancake compressor late changed to Sanden/smaller alternator also later changed to larger alt.--good thing I lowered the small alt. as far down as possible on the 1st modification)
Not much help...but you get the idea.
Bad news is....you may have to cut sections out of the 1-piece accessory mount.......I bolted a mount in place on the engine and spent a day cutting and relocating/re-welding sections onto the mount to get the clearances I needed when the components were installed.....
You may be able to cut individual component section off the original mount and bolt them to the engine rather than re-designing the whole mount.
Thanks Doorgunner. What specifically did you have to modify? Was it for compressor mounting or alternator mounting or both? It appears you have GM bracketry. Do you recall what it was pulled from. Sorry for all the questions. I wish I had 1200-1800 to plunk down on a turn key system, but that won't happen. Thanks again
I understand..the $1500 went into buying the Sanden Kit.
I may have cut out a 1.5" section on both sides of the horse-shoe mount FIRST to lower the entire top half of the original mount (15 years of lost memory)
I had to lower the Sanden until it had 1/2" clearance above the passenger valve cover--not ideal, but I removed the vlave cover only one time after the conversion.
(I may have been able to remove the useless smog pump and fit the Sanden inthat location instead, but didn't consider it)
I also cut out a radius section under the large alternator so it would lower another 1.5" and may have lowered the section that the alternator bolts to for additional clearance.
I also had to move the P/S pump toward the center of the engine to clear the upper a-arm.
I think the bracket/mount was late '80s or early '90s gm truck.
My hood would not close before....after the modifications I had an inch clearance to spare.
(Tack-weld sections into place and test fit each section before welding the section solidly onto the bracket/horseshoe...I learned that the hard(headed) way
Bolt the horseshoe to the engine and modify one component section at a time/take your time studyying the easiest way to lower each component.
There is more info on my setup in these two posts:
Post #4 in this thread: https://www.corvetteforum.com/forums...e-done-it.html
Post #8 in this thread: https://www.corvetteforum.com/forums...sion-kits.html
Good luck,
DC
