Tranny Question
Old Jun 11, 2021 | 09:35 PM
Bluesting70's Avatar
Bluesting70
2024 Corvette of the Year Winner - Modified
2023 C3 of the Year Winner - Modified
Default Tranny Question
Finally took it for a really short spin. Had to garage it prematurely because when the drive gets off of load I’m getting a moderately loud clunk that sounds like it’s coming from the transmission tail shaft area. When the car is under load, no noises. Only when coasting without any load. Never got over 8 mph. Any thoughts? New TKX with custom drive shaft. Could the yoke be slide out?
Old Jun 11, 2021 | 10:08 PM
M A Fry's Avatar
M A Fry
OK, I had the very same problem with my '69, it was the bush at the front of the diff steel bracket. Hope this helps.
Old Jun 11, 2021 | 10:23 PM
Old Man in a C's Avatar
Old Man in a C
Could be as simple as a u-joint. Not hard to verify
Old Jun 12, 2021 | 05:03 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Sloppy/loose fit between yoke and the tail housing brass internal bushing?
Old Jun 12, 2021 | 06:54 PM
Bluesting70
good call, doorgunner. I spent the whole day on it today. Lubricated the splines in the slip yoke, not the problem. Reinstalled the driveshaft, not the problem. The TKX from American Powertrain came with a custom driveshaft to fit the 5 speed. That drive shaft is 2.5” diameter. The stock is 2”. Not much clearance to the floor board. Also noticed the driveshaft isn’t perfectly centered to the floor board. Not sure if that’s stock or an issue. The Ridetech suspension package is also brand new so I raised the rear ride height about an inch and that actually reduced the amount of clunking noises. It’s like it gave the driveshaft more clearance? I’m thinking maybe get lower profile tranny mount bushings? Still can’t ride so I bummed. I did get it up to 20 mph though......so some progress.
Old Jun 13, 2021 | 08:08 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I would check your rear bushings to make sure the bushing are all good and the nuts are all tight. It shouldnt be moving that much. I had a cracked snubber that was allowing the differential to rotate causing all sorts of issues. Look where all the u joint knuckles come close to the body for wear on the fiberglass. I wore a hole through the center compartment in the rear before I found the issue.
Old Jun 13, 2021 | 11:45 AM
Bluesting70
Thanks, RR. I’m going to take a look at this today. I’m not exactly sure what the rear bushing would look like. Is their a diagram I can look up to see the breakdown? Never had the rear taken apart before so I’m guessing their is a slip yoke for that end of the driveshaft like the from to the tranny? Is that bushing there?
Old Jun 13, 2021 | 12:29 PM
doorgunner's Avatar
doorgunner
It's one of those problems where you need the car safely lifted on heavy duty (truck) jack stands so you can watch the drivetrain flex while someone engages the parking brake...then puts the car in 1st and reverse....then release the clutch JUST ENOUGH that the wheels will try to rotate.
OR....position-clamp a video / GoPro ccamera under the car so it records each drivetrain area individually while the car sits on the driveway and you make the shifts listed above as the car moves at 2-3 mph along the driveway in 1st and then Reverse...maybe even 2nd gear also.
Snubber can be loose or rotten
Example only
Also...is the differential TIGHTLY bolted to the crossmember...sometimes techs forget to torque bolts.
Old Jun 13, 2021 | 12:46 PM
Bluesting70
Example only
REALLY appreciate that, DG! I’m at the car now and it’s jack up. I think that snubber but is a little loose. Should I torque it down? Also was already scheming how I could record under car while driving it to see what’s going on. Big thanks!
Old Jun 13, 2021 | 12:56 PM
Bluesting70
Example only
just checked the snubber bushing. It’s pretty damn tight. Check out these pictures.
Not much clearance to the tunnel but NO evidence of scratching in the fiberglass.
Side view of mount. Doesn’t look like the prothane bushing is flat on the bracket. Could be because I have the rear jacked up?
Underside of the tranny mount. Maybe the two bolts are sliding back and forth when driving? That bracket is new with the kit. That worn part of the holes could be from me when installing the tranny and having to go at it a few times.
Old Jun 13, 2021 | 01:11 PM
doorgunner's Avatar
doorgunner
It's looking like Video-time...you'll see any abnormal movement and Hear abnormal sounds better...that will help you alot.
Old Jun 13, 2021 | 01:24 PM
Bluesting70
exactly. Of course it’s raining now so we wait. But I notice while under one of the two screw studs that go through the mount was loose. It was the one in the picture that showed paint scrape around the hole. Hoping it was that all along sliding back and forth. We will see.
Old Jun 13, 2021 | 01:49 PM
doorgunner's Avatar
doorgunner
FYI.......STUFF happens....
I bought a highly-rated new truck about a month ago...
a slight thump became a loud clunk.....
visual checks din't show a problem...
I finally checked stuff with wrenches.....
the driver-side U-bolts that hold the rear axle tube to the spring-pack were less than finger tight FROM the Manufacturer...
which allowed the tube to jerk up/down on the spring-pack centering pad.
Old Jun 13, 2021 | 01:53 PM
Bluesting70
I bought a new truck about a month ago..a slight thump became a loud clunk.....
yikes. That sucks. Imagine if you didn’t know about cars. You would’ve been chasing that issue for months. You would have been at the hands of how good the dealers “tech” would have been. What truck did you get?
Old Jun 13, 2021 | 04:39 PM
doorgunner's Avatar
doorgunner
Toy-o-taa...("caved/bought a foreigner")
waaaait for it.............
Old Jun 13, 2021 | 05:16 PM
Bluesting70
say it ain’t so!! Just kidding. As long as you like it, man. I’ve been considering a Silverado or Sierra lately. I currently have a 2018 Infiniti Q50 Sport as my driver on lease. Gotta decide if I’m going to buy it by January or go another direction.
Old Jun 15, 2021 | 09:51 PM
Bluesting70
So a big thanks to those that recommended the snubber!! Me and my 13 year old changed it out today in about an hour. Pretty easy job. Took it on first real drive and it was awesome after no driving for 9 months. I’m thrilled. On to alignment and tuning some minor tweaks.
I think my snubber might have been the worst one out there!
Old upper
New set from ecklers
Old lower
To Tranny Question
