68 nose emblem
Old Jun 13, 2021 | 02:49 PM
harmoe's Avatar
harmoe
Default 68 nose emblem
how do you get your hand in the back to attach the emblem?
Old Jun 13, 2021 | 04:07 PM
62corvette's Avatar
62corvette
Open the hood.
Old Jun 14, 2021 | 09:24 AM
71 Green 454's Avatar
71 Green 454
Like 62corvette stated, with the hood open there is plenty of room to have access to the front emblem nuts.
Old Jun 14, 2021 | 09:57 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
with the horns and the headlight relay there it is a pain in the As- but it can be done. You just cant see what you are doing
Old Jun 16, 2021 | 06:40 PM
loup68's Avatar
loup68
Army
If you don't have a front license plate, just remove the center grille. Pre thread the emblem nuts onto the emblem mounting studs and do not tighten it too tight. Lou.
Old Jun 16, 2021 | 08:29 PM
7T1vette's Avatar
7T1vette
You could also put some clear Gorilla emblem tape on the underside of the crossed flags and use a sharp X-acto to remove excess material. Then pull the covering off the remaining tape, engage pins in hoes and press in place. Just snug the sheet metal nuts down for permanent attachment. This will provide a 'padded' surface for the emblem so that it doesn't vibrate/rub into the paint. It is removable (dental floss and Goo Gone).
To 68 nose emblem
