Exhaust manifold
Old Jun 27, 2021 | 06:08 PM
1973bluevettee's Avatar
1973bluevettee
Default Exhaust manifold
What are those two bolts on my manifold and should the right one be screwed all the way in Liek the left one
Old Jun 27, 2021 | 06:20 PM
NONN37's Avatar
NONN37
Those manifolds had a an air injection pipe that was connected to the smog pump with hoses.
A common modification is to remove emissions components, and plug those holes. if its not leaking exhaust it should be fine.
Old Jun 27, 2021 | 06:31 PM
interpon's Avatar
interpon
And in post 11
Finally found correct pitch plug..!! Kept blowing out npt brass
https://www.corvetteforum.com/forums...tion-plug.html
To Exhaust manifold
