Astro ventilation window script
Old Jul 8, 2021 | 09:19 AM
Batesgar's Avatar
Batesgar
Default Astro ventilation window script
I recently pulled the windows out of my 68 convert non AC car and noticed the glass doesn’t have the Astro ventilation script on it. The car is an early Sept 67 build. Was the glass labeled at that time?
Old Jul 8, 2021 | 09:35 AM
sullyman56's Avatar
sullyman56
Good question. I wish I had an answer. My January build 68 door glass has the Astro ventilation script and came equipped with AC, but doesn’t have Astro ventilation. Have you checked the date codes on your glass?
Old Jul 8, 2021 | 10:09 AM
PJO's Avatar
PJO
Veteran: Marine Corps
As far as judging is concerned all 68 had the Astro Ventilation applied to all 68 Corvettes. Odds are your was replace by the PO. Check the date will be your best way to determine your issue as Sullyman56 suggested.
Old Jul 8, 2021 | 10:24 AM
Batesgar's Avatar
Batesgar
The glass did have markings, just no Astro ventilation script. I have since reinstalled the glass and put the doors back together after cleaning and lubing. Hopefully the markings are visible above door line. The car has the Astro ventilation vents inside the car.
I have seen indications that someone was in the doors before me. Just find it hard to believe they would replace both glass windows.
Is it possible they removed the script? Is the script just a sticker or was it etched in the glass?
Old Jul 8, 2021 | 10:33 AM
Batesgar's Avatar
Batesgar
Ok…just checked, markings are visible by the door handle. They read
Safety AS2 (LOF inside a outlined block) Plate XX
Solid Tempered
M51.
I have no idea how this would be a date code.
Old Jul 8, 2021 | 11:10 AM
sullyman56's Avatar
sullyman56
The date code is a two letter code. This door glass is from December 67
This door glass is from October 67. Mine are both marked M74 and that is the manufacturers model number.
Old Jul 8, 2021 | 11:25 AM
sullyman56's Avatar
sullyman56
The code XX would be February 68. Maybe your glass was replaced?
Old Jul 8, 2021 | 11:30 AM
Batesgar's Avatar
Batesgar
Agreed….I have a ton of documentation, but pretty sure none for any window replacements.
If it’s Feb 68 corvette glass, why no Astro Ventilation decal?
These are decals…correct?
Old Jul 8, 2021 | 11:41 AM
Batesgar's Avatar
Batesgar
To confuse matters further, the windshield is marked JX which is May 1968.
Why would someone replace all the glass, assumed within a year of manufacture??
Old Jul 8, 2021 | 11:52 AM
71 Green 454's Avatar
71 Green 454
Glass Codes:
Old Jul 8, 2021 | 12:02 PM
JC68's Avatar
JC68
The Astro Ventilation lettering is not a decal but looks to be silk screened on the window.
One of my convertibles side windows also has an XX date code and it has the Astro Ventilation lettering. Car was built in April 1968.
Old Jul 8, 2021 | 12:17 PM
Batesgar's Avatar
Batesgar
Thanks for the silk screen info, I was hoping for a decal but haven’t found any on line.
Your XX would align with a Apr 68 build.
Just for the records below are pictures of my window glass, windshield glass and protecto plate info.
Something don’t jive.
Window
Windshield
Protect-o-Plate
Old Jul 8, 2021 | 01:23 PM
JC68's Avatar
JC68
Your protect-o-plate is fine. All the date info lines up with the vin number.
Your glass has been replaced. A production windshield wouldn't use the wording Shaded E-Z-Eye, it would have been Shaded Soft-Ray, or Shaded Soft-Ray Tinted.
Old Jul 8, 2021 | 01:37 PM
71 Green 454
There seems to be some dispute about the Astro Ventilation script on 1968 Corvette glass.
Some say yes, some say no.
Information from Mid America Motorworks:
"1968 Coupe RH Door Glass Astro Ventilation
Manufactured to authentic OE standards and specifications, our correct reproducton 1968 Coupe RH Door Glass is a premium reproduction product. This plate glass door glass features factory correct green "Soft-Ray" tint as original.
Astro Ventilation was introduced in 1968 as a flow through of fresh air, eliminating the prior vent wing configuration. In 1969, the side glass sported white script letters at the front end of the window used into the 1975 model year.
Note;: The Astro Ventiltion script did not appear on 1968 corvette window glass."
Old Jul 8, 2021 | 02:59 PM
JC68's Avatar
JC68
I think Mid America Motorworks is wrong in their statement that factory 1968 slide glass didn't have the Astro Ventilation script.
Old Jul 8, 2021 | 03:18 PM
sullyman56's Avatar
sullyman56
I believe that they are wrong too. Both of the door glass for my 68 have the Astro ventilation script.
Old Jul 8, 2021 | 03:44 PM
Batesgar's Avatar
Batesgar
Thanks, the protect-o-plate aligns with the car stamped VIN and block. Was trying to restore the car to as original as possible. Wasn’t expecting all the glass to be a problem I won’t fix. Was just trying to figure out if the side windows should have the Astro Ventilation script.
God knows what else I’ll find along the way.
To Astro ventilation window script
Old Jul 8, 2021 | 03:48 PM
Batesgar's Avatar
Batesgar
If JC68’s convert XX date coded window have the Astro Ventilation script, why don’t my replacement XX dated coded windows have it?
Old Jul 8, 2021 | 03:58 PM
71 Green 454
I agree, it's hard to get a definite answer, but if you own one and the dates are correct, then '68's must have come from the factory with the script on the windows.
Old Jul 8, 2021 | 04:06 PM
JC68's Avatar
JC68
Service parts are not always identical to the ones used on the factory production line. My guess is they just didn't include the Astro Ventilation lettering on replacement glass. It isn't necessary for function. It also could have to do with where the replacement glass was purchased. Was it through GM or a 3rd party auto glass store.
