Shoulder belts
Old Jul 11, 2021 | 08:20 PM
Big Block 69's Avatar
Big Block 69
Default Shoulder belts
I am wanting to add shoulder belts to my very early 69 convertible. They do pop up here in the parts section from time to time. My question is, Are shoulder belts for t-top cars the same as convertible cars?
Thank You
Old Jul 11, 2021 | 10:23 PM
69FASTFUN's Avatar
69FASTFUN
Yes, get the shoulder harness for a 69 coupe. Pull back the carpet and you should have the brackets there at least they are there on my 72 convertible and I am adding them.
Old Jul 12, 2021 | 05:10 AM
Big Block 69
Thank You very much!
Old Jul 14, 2021 | 01:43 PM
68/70Vette's Avatar
68/70Vette
Thank You
Bought some sad looking shoulder belts, wrong color, on ebay. Came back from Ssnake-Oyl looking like new in the correct color. Same with the hold down straps for the T-Tops.
Old Jul 14, 2021 | 07:34 PM
wwiiavfan's Avatar
wwiiavfan
If you are not a stickler for originality, ‘93-‘98 Camaro rear seat belts are a virtual bolt-in.
Old Jul 17, 2021 | 08:39 AM
Big Block 69
No, I really don't care about originality. I just want something that will work. I want to be able to drive around with my 4 year old grandson and my daughter is concerned about the car only having lap belts. So the REAR seat belt from a 93-98 Camaro? I will look into that.
Thank You!
Rick
Old Jul 17, 2021 | 08:45 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I added some to my 68 vert and I bought ones that are vertical hung versus the hoirzontal hung ones. I got mine for a 71 so they are detachable at the seat buckle but arent retractable since the 68 retractor was short and underr the seat.....I remember it was a hassle so I went with the non-retractors and extensions
Did you locate the hole under your carpet for the anchor bolt?
Old Jul 17, 2021 | 03:50 PM
jpatrick62's Avatar
jpatrick62
What do you all think of these? Kind of a compromise between original looking, safety and economy.
3 pt seat belts
I was thinking of getting these for my 69 'vert since it did not come with a shoulder belt.
Old Jul 17, 2021 | 11:52 PM
wwiiavfan's Avatar
wwiiavfan
Thank You!
Rick
Correct. Rear seat belts from ‘93-‘98 Camaro. Make sure you get the matching “receptacle” side, the Camaro belts won’t latch to your Vette receptacles.
Old Jul 17, 2021 | 11:56 PM
wwiiavfan's Avatar
wwiiavfan
(I didn’t write this):
http://c3update.blogspot.com/p/seat-belts.html?m=1
Old Jul 18, 2021 | 06:17 PM
ddawson's Avatar
ddawson
Keep in mind the 68/69 mounts on the side above the wheel well and the 70 mounts on top of the wheel well.
This messes with the locking mechanism.
https://www.seatbeltsplus.com/product/ECONO-E69V.html
Please Note: Late 1968-1969 Shoulder Retractor mounts Vertically.Fits Coupe Only. Will Not Fit Convertible.
https://www.seatbeltsplus.com/product/ECONO-E7071H.html
Please Note: 1970-71 Shoulder Retractor mounts Horizontally. Fits Coupe Only. Will Not Fit Convertible.
Old Jul 18, 2021 | 09:04 PM
wwiiavfan's Avatar
wwiiavfan
Correct. Some folks have made an L-shaped bracket to move the mounting point on top of the wheel well for proper orientation of the Camaro belts.
Old Jul 19, 2021 | 07:19 PM
Big Block 69
I tried to feel around and couldn't find any mounting holes. So I also looked outside in the rear wheelwell and found 2 plastic plugs side by side on each side of the car directly above the frame. Is this what I am looking for?
Old Jul 19, 2021 | 11:43 PM
ddawson's Avatar
ddawson
Pull the plugs and those are threaded holes for the seat belt.
Old Jul 20, 2021 | 12:59 AM
Peterbuilt's Avatar
Peterbuilt
Don't convertible belts go through the seats and hard top belts attach with a dog bone behind the B pillar?
Old Jul 20, 2021 | 09:11 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
I just had three sets of C3 lap and shoulder belts restored by Charlie Santorelli. Outstanding quaility!
Bob K.
Old Jul 20, 2021 | 03:04 PM
Bergerboy's Avatar
Bergerboy
3 pt seat belts
I installed these in my '69 3 years ago.
They convert your lap/shoulder separated belts into a modern 3-point system with the sliding tang side.
Eliminates the key-hole plate, and keeps the lap belt off the floor when not in use.
They bolted right in place with the existing anchors and work well for retraction.
There should be an anchor on the outer side of the wheel well, same part (I think) as the seat floor anchors. If this is missing, do NOT bolt the retractors to only the fiberglass. You can get new anchors to rivet in place for peanuts.
To Shoulder belts
