Planning My MaxJax Installation
Myself, I took delivery and then brought my cars in for a sanity check with the actual Maxjax. Following that I chalked out a pattern on my garage floor, and had it cut, dug out and then refilled with some high strength concrete along with some rebar.
As to your plan to tap into a steel plate, what holds the plate itself in place? I actually have too many questions with regard to that plan to want to put to you here. Don't re-engineer something that thousands have already put in place!
I may have previously suggested that you look into the Garage Journal's thread on the Maxjax and I would suggest that you go there, cruise the thread as a whole lot more expertise can be found there as opposed to just the Corvette audience.
If I didn't previously point you to this thread here it is again.
https://www.garagejournal.com/forum/...st-here.35763/
Myself, having done the job once, the only thing I would do differently is to epoxy the anchors rather than using the expanding type. You can certainly drill bunch of holes incrementally spaced without needing a steel plate. You need a hammer drill and the hard concrete can be a bit of a challenge in terms of getting a nice hole. I messed up two of my holes and used epoxy for those two.
Here's my floor cutout. My rebar grid has room for one more bolt hole if I needed it, but so far I haven't.
I wonder If I need to go all the way across with new concrete as you did? I was just going to do 24" squares with thicker, rebar reinforced concrete.
I will look at the thread on GJ as well for ideas.
I used 3/4" LDT bolts directly into my 4" floor,, they had a better rating than the wedge bolts MaxJax recommended. And can be reused. Just woundering,,,,teddy
BTW - I went over to GJ and on the 1st page were the anchor instructions - let it be said that I would never use those anchors! You want the drop in anchors where you use a set tool to set the anchor wedge. I never trusted pound in's and here's why - if your concrete is thinner than you think, you can blow through the bottom with a pound in, wedge anchors won't do this. Maybe there was a small mound of base at that exact point, your 6" slab is now 4.5" - 5" at that one point, one good hammer blow and it will drive that anchor right through and leave a cone shaped hole, that hole is now useless. Internal wedge anchow won't do this.
That is my concern, I don't trust the concrete, it was poured buy who knows who way before I was born, and has cracks.
https://toggler.com/products/power-s...tainless-steel
The pull strength is advertised as being way better than the Web-It expanding anchors, but even when using those, if you compute the torques on the lift, there's plenty of margin.
You definitely need to determine the thickness of your concrete, mine was marginal and I had cracks where I wanted to mount the lift.
From reading the garage journal threads long ago, there seemed to be plenty of misconceptions about how to set the expanding anchors. I remember the Danmar directions from 10 years ago as well as being a little confusing as well. I tested mine by trying to pull them out. You can compute that force from knowing the thread pitch and the torque to get to a given pull strength. I was pretty amazed at how sturdy things were and the, to me, phenomenal strength these bolts have inherently.
Once you stray from the Danmar kit, you are on your own so you better be sure of what you are doing. Some of the installs I saw looked pretty sketchy but I don't see any accident reports on line.
