Graphite Grease Substitute
Old Jul 28, 2021 | 12:24 AM
78VetteSuperFan's Avatar
78VetteSuperFan
Default Graphite Grease Substitute
I’m trying to do some work on my clutch cross shaft and replace a ball stud, and according to the service manual for my 1978 I’m supposed to use graphite grease to lube the ball stud and the cross shaft. However, I can’t find any graphite grease anywhere, so I’m wondering if there’s any substitutes that I can use? Given that the placement of the ball stud is on the engine block I imagine it needs to be a high heat grease but other than that I’m not sure. I’ve been looking at Lucas Oil X-tra heavy duty grease, but I’m curious about other options or a place where I can get graphite grease.
Old Jul 28, 2021 | 10:46 AM
MelWff's Avatar
MelWff
I have owned my 69 since 73 and have always used a good quality chassis grease, same thing you use for tie rods, ball joints, etc.
