change to voltmeter
Old Aug 2, 2021 | 11:08 AM
68 beginner's Avatar
68 beginner
Default change to voltmeter
I added a 150 amp alternator....the ammeter had a black and white wire and a black wire...which should I use for my ground?
Old Aug 2, 2021 | 11:18 AM
7T1vette's Avatar
7T1vette
Neither. Both ammeter wires are 12vdc. They both come from the SAME [main] power wire, which is used as a current shunt from the resistance in the wire between the connection points of those two wires. You can use EITHER of those wires as the voltage feed for the voltmeter you are installing. Get ground from any good source tied to the chassis. It would be best to get ground from the battery -, of course. Just wrap up the other ammeter lead and insulate the open end; a future owner might want to re-install the ammeter, as it provides much more info about the 'health' of your electrical system than does a simple voltmeter.
Old Aug 2, 2021 | 02:38 PM
SteveG75's Avatar
SteveG75
Don;t forget that with a larger alternator, you will probably need to add another dedicated feed line to the battery. Our cars' wiring was not designed for anything greater than 40 to 60 amps.
Old Aug 2, 2021 | 02:49 PM
C3 Stroker's Avatar
C3 Stroker
See my reply to this thread in the Tech Performance forum....
To change to voltmeter
