Storage compartment frames
Old Aug 3, 2021 | 03:50 PM
PSU 98's Avatar
PSU 98
Default Storage compartment frames
Any insight into how to remove the rear storage compartment door frames for replacement on my 1978 Pace Car ? Mine are cracked in several places and even though they're now loose I just don't see any obvious screws or rivets holding them in place. I've found many threads here on removing the master frame and doors complete but nothing on removing just the outside frames.
Old Aug 3, 2021 | 08:09 PM
gbvette62's Avatar
gbvette62
You have to crack, break, bust, and/or grind the door frames, off of the doors. The frames were originally attached to the doors by some sort of small plastic mounting pins. Once you get the old frames off of your doors, cut or grind off whats left of the pins and frames, and clean up the edges. Next test fit the new frames to the doors to make sure you got all of the old frame, pins and adhesive off of the doors. You'll need to install the new frames using tiny screws, using the holes in the new frames to line up and drill screw holes into your old doors.
Steps 24 to 31 in the following link, explain how to disassemble and restore your rear storage compartment frames.
https://www.corvettemagazine.com/196...t-replacement/
Old Aug 3, 2021 | 09:58 PM
7T1vette's Avatar
7T1vette
The little screws are around the 'sides' of the frames. BTW, getting the screws into the NEW frames is a PITA...because of the raised knap/pile of the carpeting. The best method for installing them (that I've found, anyway) is to shave off some of the excess carpet pile that will be under the frame. Don't go so far that this approach is visible to those looking later.
Now get a 1/2" or thicker board that will completely cover the frame to be mounted and a couple of C-clamps. Place the board over the plastic frame [after you have aligned the frame so it will clear], then hold it down in place with a C-clamp on diagonal corners or opposite sides. Now you can insert the screws. DO NOT over-tighten the screws as they will crack the NEW plastic frames. Just seat them snugly into the tapered recess for the screw head. Insert ALL screws before releasing the clamps.
Hope that helps.
Old Aug 4, 2021 | 05:48 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Open the doors, the screws are on the lips on the front and rear...
Old Aug 4, 2021 | 01:40 PM
PSU 98's Avatar
PSU 98
on my ‘78 Pace Car, there are no visible screws
Old Aug 4, 2021 | 03:09 PM
Rescue Rogers
Are the hinges pop rivetted in or are there screws? Maybe check the AIM or build manual
Old Aug 4, 2021 | 07:54 PM
gbvette62's Avatar
gbvette62
Correct, the 78 had plastic doors, and the frames were bonded to the doors with some sort of adhesive and molded in plastic pins. The only compartment doors that used screws are the earlier ones with the fiberboard doors, and plastic ones that someone else has already had apart and restored, using the screws.
To Storage compartment frames
