Help please
Old Aug 3, 2021 | 10:08 PM
Mav1980's Avatar
Mav1980
4th Gear
Default Help please
Just starting my 1980 project everything looks pretty good. Put new battery in but no power anywhere ??? Maybe there is kill switch someplace any ideas
Old Aug 3, 2021 | 10:19 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Use a voltmeter to see if you have 12 volts or more at the starter where the Positive cable from the battery connects.
Also check the BAT Positive connection on the back of the Alternator for 12 volts or more.
There is also a Fusible Link in the harness that goes from the starter along the firewall...it could be melted/bad?
Let us know what you discover.
Old Aug 3, 2021 | 10:21 PM
Cmurray79's Avatar
Cmurray79
Follow the negative cable from the battery, through the battery box, and under the car. Make sure the ground is well connected to the frame and not corroded. After that, look under the dash for the fuse box, make sure everything is plugged in. Occasionally my 79 will have no power when I turn the key. There is a grey plug-in with an orange wire that sometimes works itself loose. I push that in and it starts right up.
Old Aug 4, 2021 | 01:09 AM
Mav1980's Avatar
Mav1980
4th Gear
Default Ty
I will try that this afternoon
Old Aug 4, 2021 | 02:01 AM
Bikespace's Avatar
Bikespace
Possibly the starter extension harness. (1980 L82 linked, works the same, connects the same, costs the same, and has an extra circuit that you can use or not).
https://www.zip-corvette.com/80-l82-...n-harness.html
Here's what mine looked like before I replaced it with the part from Zip. The fusable links had burned their insulation, but hadn't failed yet.
Old Aug 6, 2021 | 09:22 PM
Mav1980's Avatar
Mav1980
4th Gear
Default Delay
Ran into a slight delay a holy gas tank and I don't mean it was blessed by the pope any suggestions where to get it
Old Aug 7, 2021 | 03:54 PM
Proactive_Solutions's Avatar
Proactive_Solutions
Zip corvette. I trust their parts. I decided to replace my tank for no other reason than it’s old. Original tank sits in a box in the garage. Bought my tank at zip. It is made is Canada.
To Help please
