Mufflers
Old Aug 15, 2021 | 09:53 PM
1973bluevettee's Avatar
1973bluevettee
Default Mufflers
I have a 73 350 with hooker headers and out the back pipes and I can’t decide what mufflers to get I still want the car to be very loud and I don’t want any restriction to very little restriction and very little power loss from the muffler anyone have any advice on what mufflers would be good
Old Aug 15, 2021 | 10:32 PM
lowbuck72's Avatar
lowbuck72
I posted something regarding this a little while ago which may interest you. If you buy a pair a resonators (aka glass packs), you can control the sound. For example, if you purchased 3" ID glasspacks that are 18' long, they won't really make your exhaust that loud. However, a length of 3" plain old exhaust pipe will slip inside the glass pack perfectly. If you inserted a full 18" of pipe inside your glass pack, it would be as loud as no mufflers at all. If you inserted it halfway, it would be quieter than no mufflers, but louder than the original glasspack. So you could essentially "tune" the sound by how much plain pipe was inserted. Plus these mufflers are a bargain, $50-$75 a pair shipped on ebay.
Old Aug 15, 2021 | 10:54 PM
1973bluevettee
- thank you for responding I’ll look into that, would you say that the glass packs have a good sound and tone or would a normal muffler have a better tone?
Old Aug 16, 2021 | 12:35 PM
Eric P's Avatar
Eric P
I’d go Magna Flow
Old Aug 16, 2021 | 01:16 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Pypes has 3 levels of loud. Even the quiet street ones are pretty loud when you get on it. Those are somewhat tolerable at cruise. I believe the turbo-pros are even quieter and somewhat similar to the popular Magnaflows and pretty decent.
The other three not so much....
Duntov was quoted as saying the quiet factory mufflers kill 50 HP on a Big Block....
https://pypesexhaust.com/c-702363-gm...-corvette.html
https://pypesexhaust.com/c-702451-mu...-mufflers.html
Old Aug 16, 2021 | 01:18 PM
kansas123's Avatar
kansas123
Originally Posted by Eric P
I’d go Magna Flow
Old Aug 16, 2021 | 03:40 PM
Fredric Björnefält's Avatar
Fredric Björnefält
Black widow and Borla is bad a** 😎
Old Aug 16, 2021 | 04:00 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
I'd go SIDE PIPES !!!
Old Aug 16, 2021 | 10:29 PM
lowbuck72's Avatar
lowbuck72
If your hooker headers are long tube with equal length to the collectors, rather than y shaped shorties, you can expect a better sound when uncorked. I'd also recommend some kind of h or x pipe. That being said, run with no mufflers and see if you like the sound. Glass packs will retain the sound at a lower volume. I had some flowmasters on my other SBC which sounded the best at 2300 rpm but not loud enough for me. Ended up installing electric cutouts, which unfortunately won't fit on a C3. You could always clamp rather than weld in your mufllers. That way you could always substitute a set of straight pipes when the mood strikes.
Old Aug 16, 2021 | 11:13 PM
1973bluevettee
-they are long tube and I wasn’t planning on running a x pipe or anything just bought out the back pipes that hook up to each header and never cross over
Old Aug 16, 2021 | 11:44 PM
Vette5311's Avatar
Vette5311
Check out the “chambered” exhaust. They sound good but are a little loud when you romp on it. The good thing is if you decide later they are to loud you can add resonators where the stock muffler goes by just cutting out some pipe.
To Mufflers
