Fuel Line Routing???
Old Aug 16, 2021 | 03:39 PM
K-Dog's Avatar
K-Dog
Default Fuel Line Routing???
71 C3
Replacing Fuel Lines to Pump.
3/8th input line is getting crimped between the pump and frame. There must be a better way.
Pump is the deeper standard design. (See photo)
The old lines are still attached to the hard lines. My goal is to run the new lines off the pump, then replace the older lines once I have new lines ready.
How to route line to avoid crimping/pinching?
OK - Order the special "S" hose from Paragon Corvette. I should have known there would be a "special" hose for this! $28 bucks later.... All good under the hood.
Thanks to Aquaroscoe for the quick reply.
Old Aug 16, 2021 | 03:53 PM
aquaroscoe's Avatar
aquaroscoe
https://www.corvetteforum.com/forums...pump-woes.html
