350 - 454 clutch differences
In the process of building a 454 for my 1972 which is almost ready to be balanced, the machine shop has asked me to bring in the pressure plate and flywheel to have the whole assembly balanced.
My original is a 350, I've got the clutch assembly from it and it looks like it's seen some heat.
I have a 454 flywheel that will be machined but wondering about the clutch kits, are they the same from 350 to 454? I see a lot of listings for the 350 in my area but not for 454.
I know it's the 168 spline, but are there any fine differences?
Edit: are there any differences between the 68-72 clutches and 72 onwards (Seems they are listed this way)
"different" BUT the entire system is a matched set so it is not advised to change clutch diameter unless you have a VERY good reason. EVERYTHING is different if you change the clutch diameter.
If you are seeing some heat damage, you might want to address that. Why is it getting cooked? Not enough rear gear for the power band? Maybe just a too tight adjustment but either way, you might want to know what caused it.
