Idiot lights
Old Sep 17, 2021 | 06:17 PM
dprather's Avatar
dprather
Default Idiot lights
When you turn the key to ON, what idiot lights come on? I am replacing my dash and center console lights to LED and want to make sure I have the polarity correct. 1982 Collector's Edition. I tested the instrument lights and have those installed correctly. Not sure how to test the idiot lights.
Old Sep 17, 2021 | 06:49 PM
Bikespace's Avatar
Bikespace
Willcox has helpful color-coded diagrams of the flexible printed circuit boards.
For most lights, there is a common ground. As long as you line up the LED's cathode with that, your LEDs should work.
An exception may be the CEL, which has a separate in and out. There may be others.
http://repairs.willcoxcorvette.com/1...d-connections/
http://repairs.willcoxcorvette.com/?...rinted+circuit
Old Sep 17, 2021 | 07:01 PM
dprather's Avatar
dprather
Default Thanks bikespace
I don't want to install everything and some idiot lights don't come on because the next question would be "do I have the polarity wrong or do they not normally come on at startup".
Old Sep 18, 2021 | 03:56 AM
Eliredandblack's Avatar
Eliredandblack
It may be too late, but Superbright LEDs as well as others sell non polarized LEDs. You are correct, removing any Corvette dash more than once is insane! I have used their LEDs on three cars for dash lights, it’s the smart way to go.
To Idiot lights
