Over heating and frustrated
Old Sep 26, 2021 | 11:57 PM
Sids04's Avatar
Sids04
Check your heat riser valve if it's still there. On our 80 it was stuck closed. It would run fine around town. On the highway it would get ridiculously hot. Like 250 plus.. I wired open the heat riser and it's normal. Still did several flushes.
Is wiring the heat riser a bubba move ? Yup.. Don't care it's getting. An LS1 with TKO 600 this winter
Old Oct 16, 2021 | 10:18 AM
Nucedog01's Avatar
Nucedog01
Originally Posted by Bikespace
You should get a new spring.
can I see the lower hose collapse if I get it hot and rev the engine?
Old Oct 16, 2021 | 10:23 AM
Nucedog01's Avatar
Nucedog01
heat riser is open
I am slowly going through all these post and checking things.
been out of town for a couple weeks for work. Trying to figure it out as time allows
thanks again everyone!
Old Oct 16, 2021 | 10:28 AM
C6_Racer_X's Avatar
C6_Racer_X
Also, make sure you have all the air seals and baffles in front of and around the radiator. This might seem obvious, but air that goes around the radiator or under the radiator or over the radiator does not cool the coolant in the radiator. Those baffles and seals are there to make sure that all the air coming in the front goes through the radiator, not around it.
I suspect that the lower hose is the biggest issue here, though.
Old Oct 16, 2021 | 11:09 AM
Bikespace's Avatar
Bikespace
Squeeze the hose with your hand. An intact spring will resist. Otherwise, you will need a new spring.
With no spring, the hose will collapse when hot (car fully warmed up) and at higher RPMs. Perhaps you could see this in your driveway, but then the engine will be too warm to safely remove the radiator fluid and put a spring in the hose.
Old Oct 16, 2021 | 11:28 AM
derekderek's Avatar
derekderek
if too retarded it will run hot under load. check timing.
