Where is my gas going ?
Now the take is empty. this happened before but I just added gas and scratched my head thinking dam I went through allot of gas running the car 4 time for 10 min
Things I have done in the past 2 week :
Rebuilt 2 carburetor "uses Rochester's (might go to Holley are carb 3) and it seems to be flooding , The oil does smell but I am only over 1 quart so were did the rest of the gas go? 2-3 gallons.
There are no leaks and no smell.
The car runs rich no matter how much you turn out the mixture screws.
You turn them clockwise to lean the idle mixture.
Did you correctly adjust the float level, what did you set it to?
Did you correctly attach the clip on the needle to the float?
Electric or manual fuel pump?
Could be leaking from the carb (siphoning?) Into the cylinders?
My Holly was doing that until I had it rebuilt...but my oil smelled real bad.
Yes hard to start
1 Yes Mix screw ALL the way out not change all the way in no change but will try on 2nd carb
2 I have seen siphoning Gas Mist
3 float set 1 1/6
4 Seat installed correctly .
This was not a problem until I rebuilt my 2 carbs cause the car was sitting for 27 years and the car ran too rich on 1st few starts ( past 2 weeks)
I figured I should rebuild the carbs and i have done a few in my time so I don't understand what is wrong . It's not that hard to rebuild
I need to do another oil change ARG after only 40 min today running time, what a waste !@
If the crankcase oil does not smell like gasoline, I have no idea where the fuel is going....
I have a side question holley carburetor or Rochester. The reason I ask is because I’ve had trouble with the last three Rochester’s that I personally rebuilt that seems pretty decent. Or do I have another problem why carburetors don’t seem to run right on my car
How experienced are you at rebuilding carbs? You say you've done the three carb rebuilds - I have to respectfully suggest that maybe the issue is not with the carbs if all three don't run right. It might be worth your time to send one of the carbs out to a respected rebuilder who flow tests or actually runs the carb on a test engine. It can be money well spent.
Good suggestions have been made to confirm fuel pressure.
I'm also of the opinion that the fuel pump is suspect. If that diaphragm has a leak, the fuel will flow right through it and into the block. Fuel in the oil is not a good combination and can quickly lead to internal engine issues if the engine is run that way for long.
I have always found Holleys to be a much easier carb to use and many people have done just what you are asking - throw the Qjet away and put a Holley on with good results. This causes them to think the Qjet is junk (and some are) but when it just needed more attention paid to it during the rebuild.
I've used both and rebuilt / tuned many of each over the years. They each have their pros and cons but each will do their respective job if built and tuned as designed.
If I remember correctly, Lars has a pretty detailed Qjet paper floating around this forum or somewhere in cyberspace.
Good luck getting your car sorted. I'm sure it'll be a good runner when you do.
Tom
Now some of the stuff I’m buying is not perfect I know. I’m cleaning the ports the Jets I’ve got small tools to clean out everything and make sure there’s no clogs. I soak them in a bucket overnight. I have a feeling it’s something else there’s no way three carburetors could be ****. Now as far as the flooding scenario I don’t get that either I mean it’s pretty straightforward. You pay attention to the needle and seat you measure the height of where the float comes up with the carb I think mine is 1 1/16.
I still have to install the rear bumper work on some lighting issues I don’t plan on driving it to the spring so I think I’m gonna take a break over the winter. I’m gonna look for a good Holley carb but I had one of my Z 28 I had a 69 it worked great there to feed double pumper 650. I’m doing an oil change and replacing the fuel pump this Saturday. I do get oil and fuel are not good together especially the damage they can do the bearings if they’re not properly lubricated. Also when I run the cards generally for about 3 to 8 minutes at the most
Some of the early mechanical fuel pumps had tiny weep holes on the upper casing that fuel would leak from if the diaphragm was leaking rather than dump the fuel into the sump. In my case the fuel started to leak from these very fast, I entered the basement garage one morning to find the fuel running out from under the car
My advice on carbs: Put a Q-Jet back on the engine if you have one that can be rebuilt properly. To help you decide if a Q-Jet has a good chance of being rebuilt properly, take some pics of the carb (or carbs) you have [from upper angle view and both side views], then send them along with a request to help you decide if any are good candidates for rebuilding to Lars Grimsrud via e-mail ONLY at V8FastCars@msn.com .If one is a good candidate I would also advise that you ask if Lars would be willing to rebuild it for you. He is very reasonably priced and will be set up BETTER than a new factory carb. He will run it on his test engine so HE knows it is right before returning it to you. Best "carb" money you will ever spend.
When I change it I want to do the lines too.
https://www.zip-corvette.com/70-82-f...ed-s-hose.html
https://www.zip-corvette.com/68-82-f...e-cz-1175.html
