Loud thump or clunk!
Old Oct 1, 2021 | 04:59 PM
PKJOHN's Avatar
PKJOHN
Default Loud thump or clunk!
I have a loud thump or clunk sound coming from the rear somewhere, not all the time just periodically.
Does someone have an answer or idea of what it could be?
It only seems to do it when I’m pulling out.
Thank you,
John
Old Oct 1, 2021 | 11:17 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
The rear diff carrier snubber bushing is often the frequent culprit in the rear
Old Oct 2, 2021 | 12:42 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Thank you,
John
You'll get more feedback with greater details:
  • What model year and transmission (auto vs. 4 speed)?
  • What condition are the tires in? Unusual tread wear patterns?
  • Detail under what conditions the thump makes itself known:
    • If automatic, when shifting into gear from park?
    • Acceleration, coasting, braking?
    • Turning left, right, both?
  • Any known service to the driveline components?
Old Oct 2, 2021 | 10:11 AM
kodpkd's Avatar
kodpkd
Could be many things. Check the front snubber bracket. The one on the front of the diff, and connects to the frame cross member.
Old Oct 2, 2021 | 10:30 AM
69L88's Avatar
69L88
Agree with other posters that the front differential mount snubber is a likely culprit.
Have you checked the fluid level in the differential?
If your car is a 73-79 vintage, check the side play in the differential axles.
Find a parking lot and do some slow, tight figure 8s, both left and right. If no noise during this exercise, then you can likely exclude the posi unit.
Old Oct 4, 2021 | 01:07 PM
PKJOHN's Avatar
PKJOHN
1969 350 4 speed munch transmission, tires good condition no wear, it only clunked twice in about 5 times driving.
Old Oct 4, 2021 | 01:14 PM
PKJOHN's Avatar
PKJOHN
When I get a chance to get it on a lift, I’ll check out all your suggestions.
Thank you,
John
Old Oct 4, 2021 | 02:14 PM
L-46man's Avatar
L-46man
John...to help yourself....use the SEARCH BUTTON....I realize you're new here....That is the most POWERFUL button on the whole site.
I would presuppose this topic has been covered close to 1000 times.
Unk
Old Oct 4, 2021 | 04:49 PM
69_Shark's Avatar
69_Shark
OP:
I had your description.
427sixpack described my issue in his post!
New bushing resolved my issues!
Scott
To Loud thump or clunk!
