Original paint?
Old Oct 8, 2021 | 01:33 PM
69army's Avatar
69army
Default Original paint?
What would the best way to verify an original paint job on a 69 convertible?
Old Oct 8, 2021 | 01:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Possibly eyeball. Does the paint look 52 years old?
Old Oct 8, 2021 | 01:48 PM
210ken's Avatar
210ken
Look in all the usual places for tell tale old paint and/or evidence of masking. Under door sill plates, door jamb hinge area, under deck lid, behind headlight bezels, overspray in inner wheel wells, under gas filler lid etc.
Old Oct 8, 2021 | 01:59 PM
SEVNT6's Avatar
SEVNT6
Get a bunch of pics and show them to us...
Any idea if the mileage is original? I'd look at the chips....especially the dog legs on a '69...
Old Oct 8, 2021 | 03:04 PM
7T1vette's Avatar
7T1vette
Remove one of the door sill plates (4 screws). The surface underneath was painted with the body at the factory. If the car had a re-paint, that sill could have been painted, too. But there are usually localized spots in the vicinity which didn't get masked well and show the original paint.
Old Oct 8, 2021 | 04:45 PM
interpon's Avatar
interpon
good tips.. ill add..
- no clear (rub a small spot and see what comes off) just color
- pics
- wear through areas to count layers like inside door sills and closing areas
Old Oct 8, 2021 | 05:40 PM
Mr D.'s Avatar
Mr D.
Is the paint job crappy? If so it's factory.
Old Oct 8, 2021 | 05:58 PM
7T1vette's Avatar
7T1vette
GM "Mark of Excellence" at its best !!!
Old Oct 8, 2021 | 08:26 PM
ed427vette's Avatar
ed427vette
Look for things that don’t belong.
Look for overspray. If there is any body color paint on any suspension pieces or frame the car is repainted. Overspray on the spare tire tub is also a sign. Bodies were painted before they were dropped onto the frame so no color should be on the parts I mentioned. If you see body color on the area in the engine compartment in front of the cowl then it’s a sign of a repaint. That area should be blacked out. Often overlooked. Look for overspray under the hood on top of the black. Look for overspray on the wiper parts. Look for overspray on the door jamb striker and other parts.
There SHOULD be overspray on the headlight parts as they were installed before factory painting. But it’s also a good place to look if the factory color was changed.
Or you could post pics here.
Good luck.
Old Oct 8, 2021 | 08:30 PM
Bikespace's Avatar
Bikespace
Hold up. First, does the paint match the trim tag?
http://corvettec3.ca/interior.htm
Old Oct 8, 2021 | 10:36 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
LQQK for overspray !!!
If that doesn't help, then get a large 8" x 10" piece of sand paper rub it hard in a large clockwise circle, pressing down firmly with the center of your palm & using only 2 fingers not all 5 as not to damage the hood. Then proceed to count how many colors & layers you see
Paint meters, measuring the paint thickness are also available now.
Old Oct 8, 2021 | 10:59 PM
SEVNT6's Avatar
SEVNT6
Most of the time yes.
But every once in a while you get lucky......
Old Oct 8, 2021 | 11:32 PM
thatcorvetteguy's Avatar
thatcorvetteguy
I look for the bonding stripes. If you see them than the paint is original. If you cant see them than it's had work done.
Old Oct 9, 2021 | 01:48 AM
DKM-106's Avatar
DKM-106
2024 C3 of the Year Winner - Unmodified
If you can post high res pics that would help. There are consistencies with original paint cars and how the factory painted them. One thing to note is that of you see overspray in areas that shouldn't normally have it, I wouldn't discount that the car still has original paint. I have seen a number of examples where the plant in 69 would fix areas of the paint that was not up to standard. The plant had a lot of issues in paint and body in 69 leading to a main reason that black was discounted as a color until 1977.
Old Oct 9, 2021 | 07:43 AM
interpon's Avatar
interpon
There is also a good chance a % of the car was repainted…especially lacquer as it can be easily blended especially solid colors.
so if you see some obvious signs of repaint, it may not be 100%,
Old Oct 9, 2021 | 08:46 AM
wwiiavfan's Avatar
wwiiavfan
I didn’t know that. Mine has for sure been repainted (no black in ‘71), but I can see ghosts of the bonding strips on the rear quarters.
Old Oct 9, 2021 | 12:58 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I'd say the ability to see bonding strips is not definitive for a repaint or not. If the repaint did not include extensive filling and feathering or completely glassing in the strips then they can still telegraph through.
My '72 still wears its original paint and it's pretty obvious that a repaint hasn't been done over the last 50 years. The lacquer is crazed; thin on the fender peaks, t-tops, and hood; scuffed and chipped from wear and tear; and still has the dealer-installed pin striping! Not too pretty up close but it's a decent 20/30 car.
To Original paint?
Old Oct 9, 2021 | 01:17 PM
20mercury's Avatar
20mercury
Default Suggestion:
This method became unpopular for obvious reasons after the first check.
Wet a rag with lacquer thinner and rub an inconspicuous spot at the bottom of a fender. St Louis lacquer will dissolve and rub off color onto the rag.
Now this is not a 100% check, but unusual to repaint with lacquer plus as others say above; remove door sills, look for overspray, etc and you can likely say with maybe 90% certainty paint is original or not.
Hope this helps and if paint looks good
I say enjoy it, original or not.
Old Oct 9, 2021 | 01:33 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
You got THAT right!!!
My wife and I were just dating, when she bought her '79 C-3, brand new. The paint job on it was HORRIBLE! The dealer told her, when they delivered it, it there were any minor "hiccups" in the paint to note them, and make an appointment to bring it back. (I wasn't with her, the day she picked it up) The car was the 'frost blue', a very light color. I got a black grease pencil, and circled all the "hiccups", the day before she took it back.
When I got done with it, the car looked like a leopard....................
Old Oct 9, 2021 | 01:48 PM
barkingrats
Good luck.
You will also see "under spray" on a factory body. Look under the rear quarter panels where they wrap under and become parallel to the ground; same with the wheel flares at the forward edge of the rocker panel and the underside of the chin spoiler area. These areas commonly received little or no paint from the factory but are almost always (like 99.923% of the time) painted during a repaint because that's what responsible re-painters do.
