Wheel fitment
Old Oct 11, 2021 | 10:47 AM
77redL48's Avatar
77redL48
4th Gear
Default Wheel fitment
will 17x9.5 wheel fit '77? Without emergency brake bracket relocation?
Old Oct 11, 2021 | 03:47 PM
cagotzmann's Avatar
cagotzmann
Depends on the Backspacing and caliper spacing of the wheel.
I have 18x9.5 wheels on my 78 all around. Wheels have 4.75" backspacing & 1.1" caliper clearance. Min Caliper clearance is about .9".
Old Oct 11, 2021 | 10:53 PM
77redL48's Avatar
77redL48
4th Gear
Looks good. The rotors and calipers are factory set up.
Old Oct 12, 2021 | 12:10 PM
Old Man in a C's Avatar
Old Man in a C
I put 255/45 R18's on my rears. No problem if you move the ebrake mount. I made a simple bracket out of aluminum and attached it with screws to the top of trailing arm. I did have to grind the old bracket's welds off the side of the arm.
Old Oct 12, 2021 | 05:33 PM
77redL48's Avatar
77redL48
4th Gear
I like it. The simple straightforward solutions are the best. What rim did you choose? The set I was considering won't work.
To Wheel fitment
