What's this funky thing?
Old Nov 5, 2021 | 08:07 AM
Tommy54's Avatar
Tommy54
Default What's this funky thing?
While installing Vintage Air in my '69 big block (factory air), I discovered this. Pls let me know what you think. Thanks! PS: Sorry for the blown up pic...
Old Nov 5, 2021 | 08:14 AM
hicswa's Avatar
hicswa
Fusible link.
Old Nov 5, 2021 | 08:17 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Yes indeed, fusible link, and it's seen better days.
Old Nov 5, 2021 | 08:31 AM
7T1vette's Avatar
7T1vette
The cylindrical 'thingys' are non-flammable end pieces to the fusible link; and the insulation on it is also non-flammable. That is very important to the construction of a fusible link, because if it fails (due to some dead-short in that power line), the wire inside the insulation will melt (yes, melt) and power will be interrupted. If there were regular insulation and/or no fire-break end pieces on the link, it would start an insulation fire and "toast" the vehicle.
Makes you wonder how "lucky" some DIY folks are who replaced a GM fusible link by just sticking some smaller gauge, regular wire in its place.....
Old Nov 6, 2021 | 12:16 PM
Crimson Thunder's Avatar
Crimson Thunder
Definitely check that wire with a test light. THAT WIRE IS HOT AT ALL TIMES on my 70. Don't want to start a fire.
Old Nov 6, 2021 | 12:41 PM
OldCarBum's Avatar
OldCarBum
I get that our C3’s were designed with these scary fusible links, but wouldn’t it be better to replace these ancient fusible links by installing an inline fuse or actually install an under hood fuse block and run these circuits through spade type modern fuses?
Even if you wanted to have an all original appearing engine compartment a small fuse block is easy to conceal.
Old Nov 6, 2021 | 01:28 PM
Tommy54's Avatar
Tommy54
Got it....thanks!
Old Nov 6, 2021 | 01:31 PM
Tommy54's Avatar
Tommy54
Very helpful...thanks!
Old Nov 6, 2021 | 01:46 PM
derekderek's Avatar
derekderek
even just a wired in single blade fuse terminal...
Amazon Amazon
i have replaced pico fuses on copier power supply boards to save the boss a couple hundred dollar board...
Old Nov 13, 2021 | 09:43 AM
Tommy54's Avatar
Tommy54
Thanks. Checking it out!
Old Nov 13, 2021 | 11:47 AM
REELAV8R's Avatar
REELAV8R
If you replace it with a fuse you’ll want a slowblow type to replace a fuseable link. Allows for short period of over amperage like a fuseable link would.
Old Nov 16, 2021 | 03:53 PM
Tommy54's Avatar
Tommy54
Default Replacing my fusible link
I'd like to confirm a 30 amp blade fuse will provide the correct level of protection? Please let me know if the 30A will work OK. I'm not so good RE electrical. Will try to find info on "slow-blowd type" fuses. Working to replace my fusible link which is on its l last leg...
Thanks very much!
Old Nov 16, 2021 | 04:31 PM
REELAV8R's Avatar
REELAV8R
I don't know to tell the truth. It looks to be the GM orange 10 gauge wire in which case it could be 30 amps. A good place to start maybe. Fuseable links aren't rated the same as fuses. IMO a fuseable link should be replaced by a fuseable link. But if you want to go another route it's up to you.
This is what a slow blow looks like in case you've not seen one.
https://www.napaonline.com/en/p/BK_7821335
Old Nov 17, 2021 | 10:29 AM
Tommy54's Avatar
Tommy54
Very helpful. Thanks!
Old Nov 17, 2021 | 01:28 PM
7T1vette's Avatar
7T1vette
Fusible links have a specific purpose. They should be replaced with other properly designed fusible links....not circuit breakers or fuses.
If you think you are better at engineering the electrical system than GM / Chevy Engineering, go ahead an do whatever you want....
Old Nov 17, 2021 | 05:38 PM
OldCarBum's Avatar
OldCarBum
You might try researching out to Richard454.
He has designed several electrical circuits for our C3's and he may be able to answer your questions.
If he does provide you with a new design to replace a fusible link, please share it with us.
To What's this funky thing?
