Leak from speedo cable
Old Nov 6, 2021 | 12:53 PM
Jd21476's Avatar
Jd21476
Default Leak from speedo cable
My speedo cable to my Muncie M21 has a slight leak that tuns down the cable. I took it off the other day to check it out and I cant seem to find where an O-ring would go. I cleaned it all up nicely and put it back on but it still leaks. Should there be an o-ring and if so, where does it go?
Old Nov 7, 2021 | 06:55 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
there are o rings on the bullet. If you crawl under the car and remove the bullet you will see one on the outside and i think there is one internally
Old Nov 8, 2021 | 09:02 AM
thymer's Avatar
thymer
Same boat here, if you remove the bullet do you lose tranny fluid?
Old Nov 8, 2021 | 09:13 AM
Rescue Rogers
I never have but have a rag handy just in case
Old Nov 8, 2021 | 09:30 AM
thymer's Avatar
thymer
thanks man. My goal is to have zero leaks with my most recent project lol.
Old Nov 8, 2021 | 09:35 AM
Jd21476's Avatar
Jd21476
Im not sure what you mean by bullet. Do you have a picture?
Old Nov 8, 2021 | 09:41 AM
bmotojoe's Avatar
bmotojoe
There is an external "O" ring and a internal cup seal.
I replaced the internal seal and still had a occasional drip.
Turns out the speedometer gear shaft had worn the the inside of the housing just enough to create a slight shaft wobble.
Replaced the complete assembly no more drip.
Assembly Link:https://www.ebay.com/itm/371060429421
"O" ring and seal link:https://www.ebay.com/itm/37262850228...cAAOSw2B1dsjBe
Old Nov 8, 2021 | 07:16 PM
Rescue Rogers
Old Nov 8, 2021 | 07:19 PM
Rescue Rogers
Good luck....Ive always had a leak of some sort but Ive stopped the output shaft leaks, the rear main leaks, the oil pan leaks, the power steering leaks, distributor base leak, brake caliper leaks but the valve covers always seem to leak...IM sure when I stop that one of the others will start again....
Old Nov 9, 2021 | 08:16 AM
thymer's Avatar
thymer
Clearly you're not applying enough caulk.
Old Jan 1, 2022 | 11:42 PM
sschultz2929's Avatar
sschultz2929
To Leak from speedo cable
