Spark Plugs
Old Dec 17, 2021 | 04:33 PM
TONY NARDONE's Avatar
TONY NARDONE
4th Gear
Default Spark Plugs
I’ve got a 4 speed 72 base engine. What plugs should I be using?
Old Dec 17, 2021 | 05:20 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
NGK v-groove.
Old Dec 17, 2021 | 05:24 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Originally AC R44T if you can find them.
The Midlothian Advance Auto has them in stock.
Old Dec 18, 2021 | 12:30 AM
ntfday's Avatar
ntfday
Veteran: Marine Corps
I'm partial to E3's, just my opinion
Old Dec 18, 2021 | 06:08 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I run NGK myself.
Old Dec 18, 2021 | 01:40 PM
SEVNT6's Avatar
SEVNT6
NGK's for me too.
They gave me the smoothest idle I've ever had...
Old Dec 18, 2021 | 02:43 PM
kodpkd's Avatar
kodpkd
Just be sure that they are supposed to be tapered or not. Then whether it is extended or not.
Old Dec 18, 2021 | 08:58 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
NGK cross-reference attached; not sure why it's called "NonAuto"...
I use NGK in both of my Corvettes.
Old Dec 21, 2021 | 03:57 PM
cottoneg's Avatar
cottoneg
Like others mentioned, NGK.
Old Dec 21, 2021 | 07:59 PM
barkingrats
Funny thing about my '67's NGKs - I could order the "car" packaging but wait 3 days or they were immediately available as individual lawnmower plugs packaged on hang cards. The guy at Autozone was kinda thinking I shouldn't be using them in a car. .
Old Dec 21, 2021 | 08:37 PM
bluthundr's Avatar
bluthundr
I think I put $2 AutoLite's in it last time. They spark like they are supposed to and it makes the car go vroom vroom.
In my opinion if you're paying $8 a plug to just drive around town and cruise, you're out of your mind.
Old Dec 21, 2021 | 10:10 PM
barkingrats
The "lawnmower" NGKs were just $3 ea.
Old Dec 22, 2021 | 08:29 AM
JavaJolt78's Avatar
JavaJolt78
I use the AC Delco OE replacement type..
No idle issues since Lars did his magic on my QJet!!!
JJ78
Old Dec 22, 2021 | 10:58 AM
barkingrats
JJ78
My Delcos' terminal tips kept loosening up; even if I used pliers to snug them down, they'd work loose to only finger tight. Considered Loc-tite but the heat wouldn't work with that. Have you experienced that at all? (The NGKs are a fixed tip.)
To Spark Plugs
