R P O codes
Old Dec 20, 2021 | 01:45 PM
Scott1961's Avatar
Scott1961
Default R P O codes
I have a 1971 roadster, and don't have much info what the vehicle had for options.
Is there a way to find out what options a corvette had when ordered? SB.
Old Dec 20, 2021 | 01:49 PM
PJO's Avatar
PJO
Veteran: Marine Corps
Yes and no. The yes you would need the original window or gas tank build sheet or if it was delivered in Canada. The no as there is no other place data was saved anywhere we know of.
Old Dec 20, 2021 | 01:53 PM
Scott1961's Avatar
Scott1961
Thanks, I don't have the window sticker. It was worth a try. Thanks for your time. SB
Old Dec 20, 2021 | 02:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Here's a list.
https://corvettestory.com/corvette-o...ptionyear=1971
Compare what you find on your car with what's on the list. That'll get you in the ballpark.
Old Dec 20, 2021 | 02:15 PM
L-46man's Avatar
L-46man
Get a borescope and go down thru the rubber gas tank gasket and look at the build sheet on top of the tank....if it's still there.
To R P O codes
