Wheels
Old Dec 21, 2021 | 09:23 PM
Jukedog64's Avatar
Jukedog64
Default Wheels
Im looking to install some aftermarket Aluminum Slot Wheels on my 72 but unsure of the backspacing requirements so that i get the correct fitment.
I'll be using 15x8 size. I know the backspacing has to be correct to clear the caliper and I'd rather not have to use spacers
Appreciate any assistance
Rick
Old Dec 21, 2021 | 11:03 PM
69L88's Avatar
69L88
Factory backspacing on the 15x8 wheels is 3.5”. You should have no issues with up to a 4” backspace, assuming you stay with a standard size tire.
The issue with too much backspace is that your tire could contact the parking brake bracket that is welded to the trailing arm. Moving the bracket is a fairly common modification.
