M-20 transmission shift forks
Old Dec 28, 2021 | 06:09 PM
zblackz06's Avatar
zblackz06
Default M-20 transmission shift forks
Hey guys,
My Hurst shifter was never quite smiith while shifting my 69. The previous owner had the trans rebuilt and installed the shifter Recently examining the trans up close I noticed the the linkage plate that attach to the 1-2 and 3-4 forks had a good amount of slop in them so after ordering new linkage plates the slop is still there..time for new forks?. Is this a common issue with these transmissions? My next question is who should I purchase new forks from as I have seen new prices range from $18 to $27 per fork and they are supposed to be new units.
Old Dec 29, 2021 | 11:34 AM
birds69's Avatar
birds69
I buy all my transmission parts from Paul, at http://www.5speeds.com really great guy. he ships his parts out next day. He also has a channel on you tube called Gear Box Video.
Old Dec 29, 2021 | 05:30 PM
BKarol's Avatar
BKarol
Another place you could try is thegearbox.org. My friend just replaced the shift forks in his Muncie this past summer. He went with the more expensive made forks and stronger spring.
Muncie Shift Fork (18-096-005Heavy Duty Auto Gear) Price: $27.49 each Quantity: 2 (USA made according to the website)
Muncie Detent Levers (Set of 2) Code: 18-014-001 Price: $11.50 Quantity: 1 (product of Italy according to the website)
Muncie Heavy Duty Detent Lever Spring Code: 18-156-002 Price: $3.50 Quantity: 1
Muncie Gasket Set M20 M21 M22 1963 -1974 (1964-74 Muncie Gasket set 18-455-103) Price: $7.10 Quantity: 1
Old Dec 29, 2021 | 06:03 PM
zblackz06's Avatar
zblackz06
Thanks guys, I am actually talking g to Paul right now and he is going to try and sort through things for me.
Old Dec 31, 2021 | 06:32 AM
zblackz06's Avatar
zblackz06
Just an update on my situation, I was able tonspeak to Paul at 5speeds.com and he helped me alot and went over and above in my opinion sending me a reply to my email at around 10pm. I will be sending my m20 side cover to him for a repair and I am sure things will turn out well .
Old Dec 31, 2021 | 07:34 AM
interpon's Avatar
interpon
very cool..maybe a few before after pics and what he did to fix?
I went through him as well..reallly helped me a lot better n my m21 super t-10..and great videos, and parts..
https://www.corvetteforum.com/forums...r-etc-diy.html
Old Dec 31, 2021 | 07:52 AM
zblackz06's Avatar
zblackz06
I purchased my car a year ago and the aftermarket shifter never felt right to me so after finally pulling the trans( which was allegedly gone through by the p/o) I notice about a 1/4 inch of play forward/backward of 1-2, 3-4 shift linkage arms. Paul helped me verify that my shift linkages and arm were the correct units for my 69 with the Hurst shifter and we also verified that the excessive play in the linkage is coming from the side cover. I will be sending my side cover to Paul so he can make the necessary repair/adjustment to get this assembly shifting like butter. When my trans needs rebuilding It will be going to him also.
Old Dec 31, 2021 | 08:57 AM
BKarol's Avatar
BKarol
He does provide great videos.
In one of his videos he recommended using a stronger spring. Did he recommend changing the forks, levers, spring, also while you have it apart?
Old Dec 31, 2021 | 09:20 AM
zblackz06's Avatar
zblackz06
I am going to send the side cover to him see he can assess things. I am pretty sure this is a 40ish thousan mile car but I am also confident that the trans has seen some hard shifts in the past..meaning that the shifter was misadjust with the linkage arms causing the excessive wear.
To M-20 transmission shift forks
