snap on MT2500 scanner help
Old Jan 7, 2022 | 03:05 PM
nitan2k's Avatar
nitan2k
Default snap on MT2500 scanner help
Hello, new 1982 c3 owner here. Just bought a snap on mt2500 for my car, connected it up, and its stuck on the "connect gm-1 to 12 pin aldl" message. I do have the power connector hooked up to the adapter as well. A test light on the CEL connector pin (ckt 419) turns on, and a jump from the A-B diagnostic ports results in some clicking from around the car. The CEL light itself doesnt work but thats a whole different thread. Could someone please help me with this?
Old Jan 7, 2022 | 06:33 PM
Fly skids up!'s Avatar
Fly skids up!
Check the continuity between the ALDL and ECM. Numbers 451,461,450 are the only ones needed to read data.
Old Jan 7, 2022 | 07:26 PM
nitan2k's Avatar
nitan2k
fixed it. turns out power from cig lighter is not enough. took power directly from battery instead.
To snap on MT2500 scanner help
