Alternator Casting Code Letters
Old Jan 11, 2022 | 04:43 PM
bmotojoe's Avatar
bmotojoe
Default Alternator Casting Code Letters
My original 1977 (Left) Delco-Remy 1102474 61 AMP has a casting code AQ.
I was given another 1102474 that is dated 3 months earlier than my original and has casting code BA.
Do these letters represent anything special or just a casting plant code?
Old Jan 11, 2022 | 06:25 PM
Duke94's Avatar
Duke94
My "Corvette by the numbers" book doesn't show those characters so I would guess it is the mold cavity number like you said.
Old Jan 11, 2022 | 11:05 PM
Eliredandblack's Avatar
Eliredandblack
I believe Willcox has a table that gives the correct alternator model code for each Corvette year. The manufacturing date codes were found using Google.
Old Jan 12, 2022 | 04:14 AM
hunt4cleanair's Avatar
hunt4cleanair
Interesting I had never paid attention to those, only the broadcast code, or the alternator assembly code...this is typically what sources track as they are configured specifically for a given vehicle electrical use load (A/C...no A/C, power equipment, etc.). I would agree with your assessment a plant casting code that could be a date code, plant code or assembly line.
Old Jan 12, 2022 | 08:22 AM
bmotojoe's Avatar
bmotojoe
Thanks to all that responded!
I would like to track down the back half of the casing with a AQ or BA code as the one given to me is cracked...
Other then the crack it is a real good clean core for a 1977 with A/C built after March 8th of 77.
Old Jan 12, 2022 | 11:08 AM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I found one in my "PILE"!!!
Let me know if this will work! It has a new rear bearing too.
John
Old Jan 12, 2022 | 12:11 PM
bmotojoe's Avatar
bmotojoe
Wow John!...
What works for you including shipping to WA. 98059?
Thank You for your time...
Old Jan 12, 2022 | 12:29 PM
Go Vette Go
PM sent
Thanks!!!
To Alternator Casting Code Letters
