Original Firestone tire?
Today I dropped the spare tire in my 1973 Bigblock coupe and found it was a Firestone 721. I know the original tires on these cars were the infamous Firestone 500s which earned a justifiably explosive reputation as they were subsequently recalled and replaced by the Firestone 721s. The DOT code of the spare is W2HF 1EW144. The rule of thumb for decoding the DOT date codes for pre-2000 tires is the last 3 digits indicate the week and last digit of the year of manufacture. In this case it can be the 14th week of 1974 or 1984. I cannot find any information online about when Firestone introduced the 721. Is it possible the 721 was available as early as 1974? Thank you.
I'm going to guess your spare was replaced like that. Firestone made that tire into the '80s
I bought mine new & it came with 500s. What a POS.
My right rear blew on a deserted 2-lane in eastern Colorado back in '79...
In 1978, tire makers switched from the old letter sizing of tires, to metric sizing. The OEM size tire on your 1973 would have been GR70x15, the metric equivalent of the G70 is P225/70R15, but the tire in your tub is a P215/75R15. If it was replaced under the recall, it would be the correct OEM size, so it was more likely replaced by a previous owner for some other reason.
The things that Firestone did to avoid responsibility during the Steel Radial 500 debacle, was probably some of the worse corporate cover up and criminal behavior, ever in this country. Almost from the day they released the 500 in 72, they knew they had a problem with them. Instead of suspending sales, and not re-releasing them until they found a fix, they continued selling them and making changes along the way. Effectively using the buying public as test dummies. They fought the release of test and survey results, and refused to stop selling or recall them. As it became more clear to them that they were going to be forced by the Feds to recall them, they shipped their remaining inventory of 500's to rural areas of the south, and sold them to unsuspecting buyers at half off, or more.
I'd slowed down to around fifty when things went boom. Thank God it was a rear.
About 8 or 10 inches of tread separated but the tire held air and I got us pulled over...
Firestone refused to replace the tires on the car with something else (better), claiming that I must have been driving with them under inflated. Fortunately, my employer realized that not only was it unproductive for me to drive around on tires that were unreliable, but also dangerous, and approved my request to replace them with 4 new Goodyears. I took the 500's and dumped them at the front door of the local Firestone store, which is when I noticed they had a pile of about 30 or 40 more "under inflated" 500's beside the store. I've never owned another Firestone tire since.
