Funky looking speedometer fitting - help, please
Here's a close up shot. The short stub coming out of the transmission comes down on the passenger side of the transmission at about a 45 degree angle. It then makes a 90 degree turn to come towards the front of the car and that's where the speedo cable is spun on.
Here's the same view (from the front of the car, looking rearward), just a little further away than the close up above. You can see the speedo cable coming forward and terminating at the crazy 90-degree contraption.
One more view (from the front looking rearward), even a little further away than the middle picture. You can see the speedo cable coming forward and running through a retaining clamp.
I'm baffled by what I've got. Perhaps it's some sort of "converter" or "adaptor" as I do recall reading something along the way that mentioned these? I'm also baffled by how the "converter/adaptor" is actually held in place on the transmission case because there is no fork-shaped clamp nor does there appear to even be a place (threaded hole) where a fork-shaped clamp would be bolted in place. Maybe it's threaded into the transmission case itself? Or maybe it's pressed in?
Once I figure out what I've got, I believe that the approach to removing the cable (assuming it's the cable that is snapped) involves keeping the car up on jack stands as it is now and also supporting the transmission with another hydraulic jack. Then, unbolting the pieces that help support the transmission and which are bolted to the cross member that is right there. I would also need to undo the exhaust clamps that are holding the exhaust pipes to the exhaust clamp bracket which is also held in place by the transmission support brackets and bolts. I have to remove that main transmission support bracket in order to gain any sort of access to the speedo cable and/or the mystery "converter/adapter".
I'm hoping that one or more of you have encountered this same contraption and can give me some guidance into what I've got and what my repair approach should be.
THANKS, as always, for the contributions that you guys provide.M
It sounds like you’re saying that the adaptor screws into a very short fitting coming out of the transmission. Is that correct? It’s hard for me to tell due to the road grime but it could be a knurled collar at the end of the adaptor closest to the transmission. That would make the most sense to me.
Should I expect any fluids to come out of the short fitting after I remove the adaptor?
A set of channel lock pliers should do the trick. Maybe remove the cable from it first to get at it better
M
M
Also, are you saying that the adapter itself sticks into the transmission case? If so, what holds it in place (keeps it from just falling out)? There is nothing that I can see; check the close up picture that I posted earlier -- it's staying in there by sheer magic right now. I was under the impression based on what I see in my picture and what I've seen online that the adapter has a knurled collar, too, that screws onto something sticking out of the transmission.
While I truly like your positive attitude (fueled by the fact that you apparently did this yourself before), I can only wish that I could have the same success. I'm at a total loss as to how you managed to do it without removing the bracket(s) I was describing earlier. The adapter itself and the fitting on the side of the tranny to which it connects are directly above the support bracket(s) I mention. The passenger side exhaust runs right under there, too, as you might see in the photos posted earlier. Very cramped conditions.
If you lived nearby, I'd invite you over to give it a crack and if you managed to get it, I'd happily buy you a 6-pack of your favorite beer or a bottle of your favorite whiskey/bourbon/whatever.
The part that sticks into the transmission just mimics the end of the cable so there's only the inside part (the cable itself) and the next part goes against the end of the transmission fitting, the thin knurled nut holds it all in tight
Here's what's under the adapter you have, the inner part has the square hole that the end of the cable would go into, the outside of the cable locates against that little shoulder and the end face. So hardly anything goes into the trans at all.
The cable would have this knurled collar on the end like this
The adapter mounts the same way
M
https://www.corvetteforum.com/forums...-question.html
M
M
I'll check things a bit more tomorrow if I have the chance -- focusing on trying to look at things from a different angle (from the rear of the car) to see if things come more into focus. If I don't get a chance to do so tomorrow, it'll be many days before I can get back to it as we're going to have "grandchildren watching duty" for 5 days.
There was one anxious moment where I could not get my right hand out from between the exhaust pipe and the transmission. I got it in there… why won’t it come out? I eventually just gritted my teeth and pulled firmly and yanked it free. *phew*. I was afraid for a moment that I was going to have to chew my arm off to get out.
I took the entire adaptor-plus-cable out as a unit and then disconnected the cable once the whole thing was out of the tight location it was in. And, as you may have already figured out from this story, the cable itself is just fine; spinning it with a cordless drill registered on the speedometer as I hoped. The adaptor isn’t so fine. Spinning the drive key in it by hand would sometimes turn the end that drives the speedo cable and sometimes wouldn’t. So, it’s clearly shot.
I’m hoping to take advantage of this situation and put in an adaptor which has a gearing correction in it. The current speedo reads about 8% higher than it should, likely due to a gear change the previous owner made at the rear end. I found an adaptor supplier that has over 100 ratio-changing adaptors (both “slow down” as well as “speed up” ratios). Still waiting to hear back from them on pricing. And, yes, I know that I could change the driven gear that’s in the side of the transmission. And, depending on the cost of the adaptor I’m looking at, I may go that route. A basic 90-degree adaptor with 1:1 gearing is running around $50 based on what I’ve seen online.
I hope to never have a reason to get in there, trust me.Here is the link to the speedometer company that offers all of those gear-ratio-adjusting adapters (which fit right onto the side of the transmission, just like the one I removed did): https://speedometercablesusa.com/
When you get to their page, click on the "Gear Box Adapters" image and you'll be taken to the 250 different ratio gear box adapters (I'm only interested in the 90-degree ones) they offer. Assuming that the cost isn't astronomical for one of these, I'll be killing 2 birds with one stone: replacing my no-longer-functional 90-degree adapter and also correcting the speed shown on my speedometer.
