Vibration in pedal
Old Jan 23, 2022 | 12:26 PM
Vibguy's Avatar
Vibguy
Originally Posted by nitan2k
Ok so after some more test drives, I can't consistently recreate the problem. It just happens 50% of the time. All I can say is that It tends to happen more when accelerating on uphills, and whenever it does happen if I let my foot off of the accelerator and press it again gently, it goes away. Any ideas? again, its like a slight vibration in the pedal and a slight grinding noise under the car.
Off the wall here.....When I just read this I think detonation. How is your timing? Did you just buy some cheap gas?
Old Jan 23, 2022 | 01:01 PM
nitan2k's Avatar
nitan2k
Timing was reset back to factory (6 degrees). I run premium gas. Wouldn’t detonation problems happen at low throttle, low speed though?
