How to reduce salt damage
Old Jan 23, 2022 | 10:33 AM
nitan2k's Avatar
nitan2k
Default How to reduce salt damage
Sorry for asking this question, its a question I was hoping to never ask. I have an 82, bought 2 months ago, in pristine condition. Previous owner lived in NM, I live in MD where they salt the roads. Now, I dont drive it in the salt, but due to my living situation I have to take it out of the garage on occasion, and drive it down the driveway, where it does see salt. This might be like once or twice a week. This is completely unavoidable, so my question is how do I reduce the salt damage on the frame since there will be salt on it? Should I power wash the frame, or would that cause more damage? Are there any protective solutions I can put inside the frame to protect it?
Old Jan 23, 2022 | 10:50 AM
Bikespace's Avatar
Bikespace
If you don't have enough garages to keep the 82 in one all winter, you should buy or build another garage, store the car off-site in a rented garage, or sell it.
Isn't it your choice if you salt your own driveway? Just drive slow. The splashed brine does the damage, followed buy salt dust kicked up by the wheels.
Old Jan 23, 2022 | 10:56 AM
derekderek's Avatar
derekderek
maybe fire up the hose if it is thawed and wash driveway down before you have to pull the car onto it. although as bikespace said, driveway speed does not sling brine up and unless you are following cars the day after a snowstorm you won't get salt into the windshield frame area. i had a wave come in the passenger window of a 68 camaro driving along daytona beach in 78. pretty sure the guy who owned it started cursing my existance a few years later. so staying away from the ocean may also reduce salt damage...
Old Jan 23, 2022 | 11:25 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I also doubt that you will get any corrosion from salt just moving the car in the driveway. But if you still have concerns, there are pressure washer attachments designed for undercarriage cleaning. Several spray nozzles that point upward in a manifold mounted on wheels. Spray as required. Also, you can have the undercarriage professionally sprayed with a rust protector.
Old Jan 23, 2022 | 11:33 AM
69L88's Avatar
69L88
Can’t imagine you getting salt on anything but the tires if all you are you are doing is moving it in and out of the garage. Don’t overthink your situation.
Old Jan 23, 2022 | 11:39 AM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
There's probably more salt in the air that will cause corrosion than will get on your car by moving it in the driveway.
Old Jan 23, 2022 | 12:27 PM
DarrellD23's Avatar
DarrellD23
The op said he drives it on the highway and not just the driveway. The highway and salt is the problem not the driveway.
Old Jan 23, 2022 | 12:38 PM
leadfoot4's Avatar
leadfoot4
OP, spray the frame with a corrosion inhibitor called "LPS 3". While this product comes in aerosol in spray cans, the more economical way to dispense it, is to buy a 1 gallon can, then use an HD plastic hand spray bottle.
Old Jan 23, 2022 | 12:52 PM
ebbnflow's Avatar
ebbnflow
yup ... LPS is a whole line of Very good chemicals
Old Jan 23, 2022 | 12:57 PM
nitan2k's Avatar
nitan2k
Thank you all for the reply’s. The driveway isn’t ours, so not our choice to salt it or not. And it’s kind of long so hosing it down isn’t an option. I do drive very slow on the driveway as to not kick up salt, but let’s run under the assumption that salt does get kicked up. So consensus is that pressure wash is ok? Also I will try this LPS. Can I spray this or some other protector on the inside of the frame as well? It’s the inside that I’m most concerned about
Old Jan 23, 2022 | 01:09 PM
leadfoot4's Avatar
leadfoot4
Absolutely, and in fact, I highly recommend it! Years ago, as a "side hustle", I used to rustproof cars, as I live in the "snow belt', otherwise know as the "salt belt", due to the use of road salt. I used LPS3 to rustproof the interior areas of cars, such as inside the doors, quarter panels, front fenders, frames, etc.
Old Jan 23, 2022 | 01:21 PM
nitan2k's Avatar
nitan2k
Sweet. Do you know of any spray hoses or such that can reach around in the inside of the square frame, so I can spray the hard to reach areas? I image something like a flexible hose, thin enough to fit inside one of the drain holes, with a spray fitting at the end of it so it reaches all 4 sides of the frame.
Old Jan 23, 2022 | 01:55 PM
wwiiavfan's Avatar
wwiiavfan
As others have said, don’t overthink it too much, but if it makes you feel better, you can rinse the underside of the car off with a 10% vinegar-water solution to help neutralize the salt, followed by a clear water rinse. Used to do this when I got the urge to take the Harley out in the wintertime in Wisconsin. (30 degree Christmas morning ride was awesome!). Did it work? I can’t say for sure, but I never had any corrosion in my bike.
Old Jan 23, 2022 | 02:22 PM
TX427C3's Avatar
TX427C3
What post are you reading?
"Now, I dont drive it in the salt"
Old Jan 23, 2022 | 02:24 PM
nitan2k's Avatar
nitan2k
Correct, I dont drive on highway. But for the sake of information, lets just assume that salt does get kicked up into the undercarriage.
Old Jan 23, 2022 | 02:31 PM
TX427C3's Avatar
TX427C3
Youv'e been given some good suggestions
Even in the garage I'd keep a breathable cover on it too.
Old Jan 23, 2022 | 02:32 PM
nitan2k's Avatar
nitan2k
Yes the suggestions thus far have been great. Whats the purpose behind a cover in the garage though?
To How to reduce salt damage
Old Jan 23, 2022 | 04:56 PM
leadfoot4's Avatar
leadfoot4
I have a spray gun assembly that has a length of flexible plastic hose on it, but it attaches to an air hose that's hooked to my air compressor. Off hand, I dom't know of anything that would connect to a "hand powered" spray bottle. However, if you have a wholesale cleaning supply wholesaler, and you could get a serious spray bottle from them, those sprayers usually have an adjustable nozzle, and will spray a stream 8-10".
Old Jan 23, 2022 | 05:02 PM
nitan2k's Avatar
nitan2k
thats fine, air compressor is actually preferable! Im gonna find something similar to what you have. Should I clean out the inside frame with water or something then apply the solution?
Old Jan 23, 2022 | 05:11 PM
nitan2k's Avatar
nitan2k
Also, leadfoot4, what do you know about POR 15 or Eastwood? I found this
im not sure about the product, but that spray tube looks exactly like what I want. Full cone coverage on the inside.I’ll stick with LPS if that’s the superior product though
