1973 Belt
Old Feb 11, 2022 | 12:09 PM
jmgreer1's Avatar
jmgreer1
Default 1973 Belt
1973 w350, power steering, A/C. I have a squealing fan/alternator belt. In order to get the squeal out, the amount of tension needed makes it contact the power steering pump. I tried slipping a smaller sized belt on it, but the next size down won't fit over the pulleys. I read somewhere that most auto parts stores will sell you a belt, but that the car actually needs a wider belt than what stores carry. Any truth to this?
What size belts should I have? The one on it now (that squeals) is a 138.5. A 136 is too short to go on.
Old Feb 11, 2022 | 12:41 PM
MelWff's Avatar
MelWff
The original belt was part number 326089 with dimensions of 3/8" x 54 1/4".
I have no idea what your two numbers, 136 and 138.5, represent.
Here is a NAPA belt
https://www.napaonline.com/en/p/PBH1...pressionRank=1
Old Feb 11, 2022 | 12:46 PM
jmgreer1's Avatar
jmgreer1
That's the length in cm. 138.5 is 54 1/2". I need to check the width if it is 3/8" or not. Still look long according to original specs.
Old Feb 11, 2022 | 12:54 PM
MelWff's Avatar
MelWff
The NAPA belt is the correct length and width. In cm it's 137.8.
Old Feb 11, 2022 | 01:04 PM
jmgreer1's Avatar
jmgreer1
I am going to pick one up. Hope this solves my problem.
Old Feb 11, 2022 | 01:16 PM
MelWff's Avatar
MelWff
Make sure it's PBH 15543, they had a number of belts listed for the application but this is the only correct one dimension wise.
To 1973 Belt
