Transmission
Old Feb 27, 2022 | 02:29 PM
Golferdad's Avatar
Golferdad
Default Transmission
I drove my car yesterday Mourning about 30 minutes,trying to figure why it’s idling so high,which I never did get to calm down,but had no problem with it shifting 3 gears,drove back home and mess with the carburetor and finally got the idle down,I just replaced the plugs a few days earlier,and just wanted to check one and look at it,so the easiest one is on the passenger side,so was taking it out and accidentally hit the starter and shorted the wire out,and burnt it into,so fixed the wire back and cranked it up took it down the road,and then it want shift into 2nd,so took back home,so any possibilities did I perhaps short something else to prevent the transmission from shifting.
Old Feb 27, 2022 | 06:10 PM
Motorvation's Avatar
Motorvation
Check your vacuum modulator line.
Steve O.
Old Feb 27, 2022 | 08:12 PM
Golferdad's Avatar
Golferdad
Thanks,I will,I had it jacked up the same day replacing plugs and wires,and could have easily broke or knocked something loose accidentally.
Old Feb 28, 2022 | 04:17 PM
Golferdad's Avatar
Golferdad
Thanks,that’s what is was vacuum line was off,I put back on and put a tie strap on.but at least will know if it happens again. Thanks again.
To Transmission
