75 radio problem
Old Mar 7, 2022 | 09:34 PM
grady white's Avatar
grady white
Default 75 radio problem
Hi when I turn up the volume all the way up on my original 75 radio I can hear the music playing but it is very weak .. Any help would be appreciated .. also did 75 come with a power antenna thanks
Old Mar 7, 2022 | 10:23 PM
KingRat's Avatar
KingRat
No power antenna.
No affiliation but if you send your radio to Robert Pacini @ Precision Stereo Repair 6475 Stage Rd Utica, NY 13502 He can "hot rod" the internals of your radio so that it will play better than new and add an mp3 jack to the back so you can play music from your phone etc. He did it to my '80's original AM/FM/CB radio and I am very happy with it.
Old Mar 8, 2022 | 08:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Test the convector;
Old Mar 8, 2022 | 08:35 AM
grady white
Originally Posted by KingRat
No power antenna.
thank u .. can I remove the radio without taking off the bezel. Thanks
Old Mar 8, 2022 | 08:37 AM
VERYSOON's Avatar
VERYSOON
Default convector
How do you test the convector????
VS
Test the convector;
Old Mar 8, 2022 | 09:40 AM
kansas123's Avatar
kansas123
I can't tell you exactly how I did it, but I did it in my '72. I was quite intent on getting it out without all the other disassembly believe me.....
Old Mar 9, 2022 | 08:23 AM
grady white
No power antenna.
thank you for the referral !! I called him he said at least a 6 month wait 🤦‍♂️
Old Mar 9, 2022 | 08:49 AM
interpon's Avatar
interpon
worth it on all fronts..
in the mean time, a cheap portable bluetooth speaker that when done can use elsewhere..
Old Mar 9, 2022 | 09:31 AM
KingRat's Avatar
KingRat
Wow! That is good for Robert. He is a stand up guy that does excellent work.
Old Mar 9, 2022 | 10:02 PM
glinares's Avatar
glinares
I had a similar issue. Here is the thread:
https://www.corvetteforum.com/forums...-not-work.html
Good luck,
George
Old Mar 10, 2022 | 10:53 AM
derekderek's Avatar
derekderek
first find a speaker wire and hook it up to another speaker to rule that side out.
Old Mar 10, 2022 | 02:10 PM
L-46man's Avatar
L-46man
Default Antenna trim pot
Did you happen to change the antenna? There is a 'antenna trimmer pot' behind the station change ****. (tiny little flat bladed screw hole).
Is this an amplifier problem or a weak signal problem???
Unkahal
To 75 radio problem
